Re: Have ye seen deez Sachs Clutch disks
DrGeorgeTompson (Alan) /
So I Finally got around to jamming more shit into the clutch.
Turns out I just spun the nut off this time instead of glazing everything over. No problem, I ordered 100 (lol McMaster) thin M10x1.00 nuts to jam and hopefully prevent that. They are ~5mm thick; Idk if i'll have to make them even thinner to fit two on the end of the crank proper or not, but i'll figure it out. Stock nut is 6mm but there's a little bit of crank sticking out.
I was able to make it a 7 piece fairly easily and may not even need that much clutch if I was just spinning the nut off with the two springs.
Anyways, I ended up having one 3.2mm pad and one that was 4.2mm in the clutch to begin with. I don't think it was swollen or anything, it was just bigger. Idk.
I Was able to fit 2 springs, 4 discs, and 3 pads in without much trouble. I removed the end spacer (#15) that sits on the splined piece (#19) from the stack. The whole stack came to about 17mm so the 18mm pins stick out about 3mm. Might be too much pin stickage; not sure yet.
So going in towards the crankcase, here's the plan:
-outer bell-lookin' nipple piece (11)
-Nut (2 jammed) (m10x1.00 Thin nuts)
-fat washer that could be round but is not for whatever reason (13)
-1.7mm disc (16)
-3.2mm pad (18)
-1.7mm disc (16)
-3.2mm pad (18)
-1.7mm disc (16)
-3.2mm pad (18)
-1.7mm disc (16)
-Fingerly Discy springy thingy (20)
-Fat bottom spacer (21)
-weird little washer shim with SPEED holes in it (22)
-Clutch bell (23)
I did run into some fitment issues getting the clutch actuator piece (#7) onto the stick (#5).
I think the longer pins pushed the nipple bell (11) out a bit so it was difficult to get onto the stick (#5) cause it rubbed a bit. I ground some of the actuator jobbie (#7) off and it fits. I have 2 of part #11 and plan to make one a little shorter to help with this and make sure the brass screwy bit (#9) hits the proper mark.
When pulling the clutch lever it doesn't really seem to spread the pads much, but it does open and let the wheel spin.
I have not put the cover back on and I might have clearance issues with that. More gaskets will fix.
I kinda want to get a handful of the spring washers from the auto clutches just to help space everything out when the clutch is opened to hopefully mitigate drag and such.
Also, holy shit my clutch hand is sore.(edited)
  Have ye seen deez Sachs Clutch disksTopic by: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 12:00PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/10/17 01:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: Cpt. F. Cpt. F. 05/10/17 01:08PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 01:14PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/10/17 01:42PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 01:55PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/10/17 05:45PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 02:30AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/11/17 09:13AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 12:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 12:07PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/11/17 09:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/10/17 03:29PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 03:31PM
  Re: Have ye seen deez Sachs Clutch disksRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/24/17 03:05PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/24/17 03:10PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/24/17 05:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 10:06AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/25/17 03:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 03:48PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 06/03/17 08:52AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/05/17 11:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/26/17 08:09PM
  Re: Have ye seen deez Sachs Clutch disksRe: Graham Motzing Graham Motzing 05/24/17 04:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/24/17 04:52PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 10:19AM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/06/17 04:43PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/06/17 04:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: - Dacruzer - - Dacruzer - 06/29/17 06:15PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/06/17 05:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/06/17 05:52PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/07/17 12:29PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/07/17 12:46PM
  Re: Have ye seen deez Sachs Clutch disksRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/10/17 09:55AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 07/10/17 01:57PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/10/17 02:00PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/07/17 02:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: CtpEDsHED . CtpEDsHED . 06/12/17 04:02AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/12/17 09:32AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/22/17 10:16AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/22/17 12:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/22/17 01:20PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/22/17 01:51PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/23/17 07:51PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/23/17 08:25PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/27/17 03:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/27/17 03:49PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/27/17 04:24PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/10/17 10:21AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/13/17 02:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/16/17 10:46AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 08/17/17 05:25PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/17/17 03:35PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/17/17 03:37PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/17/17 04:09PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/26/17 05:21PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/27/17 11:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/28/17 07:11PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/29/17 10:49AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 08/29/17 03:30PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/29/17 04:34PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/29/17 04:39PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/30/17 01:17PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 01:12PM
  Re: Have ye seen deez Sachs Clutch disksRe: EH FCC of the QCB EH FCC of the QCB 08/30/17 09:53PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 08/31/17 01:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 01:57PM
  Re: Have ye seen deez Sachs Clutch disksRe: Axldeziak . Axldeziak . 08/31/17 02:19PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 02:23PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 08/31/17 04:50PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 09/01/17 02:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 09/01/17 02:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: Neil Shaddox Neil Shaddox 09/20/17 11:22AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/20/17 12:11PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/20/17 04:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/20/17 09:55PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/17 10:39AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/26/17 10:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: P D P D 11/26/17 12:02PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/27/17 01:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: P D P D 11/27/17 09:42PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/19 07:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/21/17 01:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 11/21/17 02:50PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/17 03:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 12/13/17 05:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/19 02:13PM
  Re: Have ye seen deez Sachs Clutch disksRe: Daniel '' Daniel '' 03/09/19 06:35PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 03/11/19 10:11AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/11/19 10:26AM
  Re: Have ye seen deez Sachs Clutch disksRe: Chris Squid Chris Squid 03/11/19 05:53PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 03/14/19 10:32AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/14/19 11:17AM
