Re: Have ye seen deez Sachs Clutch disks
Born to be WillD /
super curious/amused by the shifter setup
I think it's true the 7 pieces had a longer spliney piece but you can still make 7 fit on the shorter ones. you just need the thin plates. like usually each set had one thinner clutch plate (2 @ 2.3, 1 @ 1.7) and you use all three of the thinner ones - but yea requires some digging or someone with a pile of sachs clutch sets.
then you can ditch the outer alignment washer from your manual clutch set or the thick outer shims on the automatics. Then it lines up pretty well.
with the 9 pc ubers it was hard to even fit in the clutch bell lengthwise
The setscrew doesn't help much except if you're spinning the nut off a lot. which used to be a big problem with sachs but I've found usually just the 2 thinner nuts locked together is totally sufficient
Maybe shimming can give you some better grip? you can add spacers under the compression spring retainer guy on the back.
  Have ye seen deez Sachs Clutch disksTopic by: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 12:00PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/10/17 01:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: Cpt. F. Cpt. F. 05/10/17 01:08PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 01:14PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/10/17 01:42PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 01:55PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/10/17 05:45PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 02:30AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/11/17 09:13AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 12:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 12:07PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/11/17 09:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/10/17 03:29PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 03:31PM
  Re: Have ye seen deez Sachs Clutch disksRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/24/17 03:05PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/24/17 03:10PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/24/17 05:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 10:06AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/25/17 03:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 03:48PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 06/03/17 08:52AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/05/17 11:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/26/17 08:09PM
  Re: Have ye seen deez Sachs Clutch disksRe: Graham Motzing Graham Motzing 05/24/17 04:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/24/17 04:52PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 10:19AM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/06/17 04:43PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/06/17 04:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: - Dacruzer - - Dacruzer - 06/29/17 06:15PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/06/17 05:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/06/17 05:52PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/07/17 12:29PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/07/17 12:46PM
  Re: Have ye seen deez Sachs Clutch disksRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/10/17 09:55AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 07/10/17 01:57PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/10/17 02:00PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/07/17 02:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: CtpEDsHED . CtpEDsHED . 06/12/17 04:02AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/12/17 09:32AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/22/17 10:16AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/22/17 12:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/22/17 01:20PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/22/17 01:51PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/23/17 07:51PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/23/17 08:25PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/27/17 03:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/27/17 03:49PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/27/17 04:24PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/10/17 10:21AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/13/17 02:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/16/17 10:46AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 08/17/17 05:25PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/17/17 03:35PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/17/17 03:37PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/17/17 04:09PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/26/17 05:21PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/27/17 11:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/28/17 07:11PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/29/17 10:49AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 08/29/17 03:30PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/29/17 04:34PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/29/17 04:39PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/30/17 01:17PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 01:12PM
  Re: Have ye seen deez Sachs Clutch disksRe: EH FCC of the QCB EH FCC of the QCB 08/30/17 09:53PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 08/31/17 01:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 01:57PM
  Re: Have ye seen deez Sachs Clutch disksRe: Axldeziak . Axldeziak . 08/31/17 02:19PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 02:23PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 08/31/17 04:50PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 09/01/17 02:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 09/01/17 02:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: Neil Shaddox Neil Shaddox 09/20/17 11:22AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/20/17 12:11PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/20/17 04:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/20/17 09:55PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/17 10:39AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/26/17 10:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: P D P D 11/26/17 12:02PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/27/17 01:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: P D P D 11/27/17 09:42PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/19 07:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/21/17 01:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 11/21/17 02:50PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/17 03:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 12/13/17 05:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/19 02:13PM
  Re: Have ye seen deez Sachs Clutch disksRe: Daniel '' Daniel '' 03/09/19 06:35PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 03/11/19 10:11AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/11/19 10:26AM
  Re: Have ye seen deez Sachs Clutch disksRe: Chris Squid Chris Squid 03/11/19 05:53PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 03/14/19 10:32AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/14/19 11:17AM
