Compression Ratio/RPMs
Does anyone know what the compression ratio is for a Honda hobbit PA 50? RPMs would be good information as well. I would like to know These numbers on a bone stock bike. Unfortunately, the manual does not allude to these numbers.
Re: Compression Ratio/RPMs
The compression ratio is listed as 6.5:1 for the 25-30 MPH version. (113.78 to 170.68 PSI, tested by kicking the engine over with the throttle fully open).
max rpm? stock is like 6000-6500 on a pa50-2, probably 4500-5000 on a PA-1.
Thanks guys!
so compression directly relates to RPM? interesting, well yeah, that does make sense. i have to read more.
Compression ratio is just the difference in volume between Top Dead Center and Bottom dead Center.
Or, in 2 stroke applications like Mopeds, the difference in Trapped Volume between when the exhaust port closes and top dead center.
A low compression ratio Can prevent you from attaining top RPMs, because you run out of Torque before you hit any other limiting factor.
A very high compression ratio can prevent you from reaching high RPMs because the act of compressing all that gas on the upstroke is a static tax on power. You get more Torque out of the power stroke, sure, but at a certain point in the rev range it'll start costing you power.
Way better to use a tuned pipe to boost your compression ratio when you're near peak power anyways, that way you get an engine that revs freely but still delivers torque where it's needed.
According to Honda Belgium 5950rpm max for PA50-1 and 6460rpm max for PA50-2 both giving up 2hp at 5500 and both with 6,7:1 compression ratio.
Nicolas DiGirolamo /
> What would the estimate be on a 70cc kitted Hobbit? Is there a way I could calculate this? Yes I know this is an older post but thought I would still ask.
🦺πŸ₯‡b to the MOPO 🚨🚨🚨 eff /
That totally depends on your setup. Somewhere in the 9k-11k range isn't too hard by slapping together parts.
Jesse Nordlander /
I like to take .8mm off the top of cylinder on stock Hobbit.
