Re: hobbit one-way bearing spacer
James Culver /
^^HAHaha...
i've been know to wear clothes...
@Todd, Thank you!
I recently saw the POWA of a a one way bearing on James Derbi!!!!
Amazing \m/ Honest™
Just did this mod on a PP/PR clutch bell. Haven't had time to swap it onto a running bike yet but fitting on a spare bottom end looks real promising.
Charles Cole (OFMC) /
Lets keep this thread alive. More pix please,
campeona del mundo /
been rocking 1way on my slex for 2 years now. fun stuff...
also been rocking one on my single speed ciao...hehehe
there's a kit on ebay now for 40 bucks. fits well works well.
One Way Bearing
Here's a video of me installing it. Get you one!
Gonna do a derbi kit also?
I didnt make the kit, but the guy said he was working on a flatreed one!
It is very simple to make a universal version which works on both derbi and hobbit.
So how exactly would be the derbi version of this kit differ?
Like, If you bought this hobbit kit, whats stopping you from using it in the hobbit version ebay kit thing-a-mahbob?
I've got Nate's on my mutant hobbit and just grabbed that eBay kit for a possible water cooler revision of my stocko shocko. It is freaking amazing. Could this theory work on a variated vespa. That would make the mlm water cooled head for vespa make sense.
Dirty30 Dillon /
Could work for vespa, probably easier than hobbit as well. Just find a one way version of the rear clutch needle bearing.
I have a few spares and will attempt it
This one way bearing is so freaking cool. It really just goes in one direction. It's so strange to feel it. It's absolute. No slop. Yea it's new.
Can this spacer work on a paper 50 1 set up?? I was saving it for a future water-cooler pa 50 2 but I could just pop it on my stockcoshocko which is set up with a part 501 crank and variator. And get the Puch head.
While on the one way bearing jag , im wondering about vespa one waydom! There are two roller bearings in each unit. One on each end. Might need to take both out to replace even one. Wondering if two one ways or just one is in order. I'll probably start a new post. The best reason to do this that I can think of is to go for the mlm water-cooler head. If u think a hobbit head sucks u ought to try getting a verspa kit to run cool at wot . Otherwise not a super motivation for a one way bearing other to say u did it. The one without the lock washer would be my first victim. Any body press out those bearings ?
Dirty30 Dillon /
Marc,
They're just drawn cup needle bearings, they press out fine. The problem is you're going to have to hunt down the right one-way bearing, which I don't think exists.
You could do watercooled with this, but there's also pull start and kickstart options you can get to avoid start shoes.
Yup to the above. Before disassembly im going to try and find such a one way beastie
Give up on this foolish pipe dream. These one way tinkertoys don't work. Pedal start is the only answer. Perhaps a length of twine on some sort of spool that could be grunted upwards in a brisk motion is the answer.
Lets all stop this subhuman speculation.
> and hobbit.
the ebay kit for PP and for Hobbit are exactly the same, but the Flatreed seems to be the same but has some washers to make up for the bushing not being quite long enough to clear the threads for pressure from the nut.
if you put this in your pa1 bell just get a stuffy crank and it'll bolt up perfecto
