if you live in savannah, going uptown on any main road you will cross henry and anderson streets. both have stoplights and they are 1 block apart. at night they are set so the far one turns green before the one you're stopped at. i fucking refuse to stop twice, so i lead it and run yellows all day. sometimes if i get stuck in the middle, i'll alley it over a block and cheat that shit.
well anyway, a bike that can stop at that first light, then wait till it turns green, and make it through the next one before it turns yellow has good accel and at least goes 40.
i don't like wearing my temp gauge out. i get the bike close to what i think is good, then test it with the gauge. i got a good wide open max speed test lap that's about 1/2 mile of slight down hill, then right back up it. i can usually get as hot as i'm gonna on that run. then i put the gauge away so i don't wreck it again...
the next test is tybee island. you pretty much run wide open for half an hour. 3 bridges, turtle x-ing signs, and a couple miles of 1 lane road w/ 50mph limit, so you kinda gotta go fast so as not to be a shithead. then you go swimming! if you make it back, congratulations! you've built a pretty good moped!
the first time i rode all the way to the beach and back was on my first kit ever. it went pretty good. by the time i got back, my bike was going all slow and i thought i killed it. i took it all apart. checked the piston first. kit was fine. rear tire was rubbing swingarm. bahhh! tuning was spot on. didn't even get too hot buring up all that rubber.
