Re: Metra 65 puch kit questions
Probably Fred /
Ya a 16.16 carb has a small range so if you lean it enough for a good idle it will be lean on top so puchs with performance piston port kits/cylinders and pipe hate them.
Every puch I got or worked on that had a 16.16 sha on a pp kit had cylinder damage.
On a puch Reed kit a sha (15.15 or smaller is better/has better air/fuel mix) is not so bad you can richen them up for enough gas on top and because of the reeds they still may still idle but not on a performance build PP kit.
Use a highly tunable carb on your metra kit like a phva (a 17.5 phva just rips) or phbg that has starter, idle, progressive, mid and full throttle systems so your cylinder is not starved for fuel (and oil) see link:
Set timing low or use a retarding ignition and protect with a head temp gauge
http://www.mypage.tsn.cc/rdd/TT/contents/CARB/dellorto/index.html
  Metra 65 puch kit questionsTopic by: David Conn David Conn 03/13/17 04:38AM
  Re: Metra 65 puch kit questionsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/13/17 09:08AM
  Re: Metra 65 puch kit questionsRe: Probably Fred Probably Fred 03/13/17 12:27PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/13/17 04:35PM
  Re: Metra 65 puch kit questionsRe: Probably Fred Probably Fred 03/13/17 04:58PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/13/17 05:11PM
  Re: Metra 65 puch kit questionsRe: Kansas John Kansas John 03/13/17 05:42PM
  Re: Metra 65 puch kit questionsRe: Graham Motzing Graham Motzing 03/13/17 10:57PM
  Re: Metra 65 puch kit questionsRe: Kansas John Kansas John 03/14/17 06:55PM
  Re: Metra 65 puch kit questionsRe: Jesse Stephenson Jesse Stephenson 03/14/17 08:17PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/15/17 10:07PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/15/17 10:19PM
  Re: Metra 65 puch kit questionsRe: Ben Whittle Ben Whittle 03/15/17 10:56PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/21/17 09:32PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/21/17 09:40PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/21/17 09:45PM
  Re: Metra 65 puch kit questionsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/21/17 09:56PM
  Re: Metra 65 puch kit questionsRe: Graham Motzing Graham Motzing 03/23/17 12:45AM
