Metra 65 puch kit questions
David Conn /
Hello, bear with me for a bit I am new to mopeds and 2 strokes in general. A little more than a month ago I bought a puch magnum with an e50 motor under it. It had a metra 65 kit on it, a dellorto sha 16:16 carb and a performance exhaust. It had no air filter either. Well at the time it wouldn't start easy but would start and run rather well. It progressively got harder and harder to start until it wouldn't. I did a compression test on it the othèr day and the readings were very low at 75psi, so I figured the rings were done for. They are and the piston and cylinder, so much scoring on bottom side of piston and the cylinder. So today I ordered the same kit to install. Does anyone have an idea what might have gone wrong? Play in connecting arm? To rich or lean? I know the lack of an air filter contributed to it as well if not for all of it. Piston installed upside down? Anyways I was curious about jetting as well. What jet would for a 16 16 would you all run on this moped and what spark plug as Well? It has a ngk b7hs on it currently. I want to apologize as well as I am uncertain as to whether i should post this in performance or the repair sections. Thanks allot
  Metra 65 puch kit questionsTopic by: David Conn David Conn 03/13/17 04:38AM
  Re: Metra 65 puch kit questionsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/13/17 09:08AM
  Re: Metra 65 puch kit questionsRe: Probably Fred Probably Fred 03/13/17 12:27PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/13/17 04:35PM
  Re: Metra 65 puch kit questionsRe: Probably Fred Probably Fred 03/13/17 04:58PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/13/17 05:11PM
  Re: Metra 65 puch kit questionsRe: Kansas John Kansas John 03/13/17 05:42PM
  Re: Metra 65 puch kit questionsRe: Graham Motzing Graham Motzing 03/13/17 10:57PM
  Re: Metra 65 puch kit questionsRe: Kansas John Kansas John 03/14/17 06:55PM
  Re: Metra 65 puch kit questionsRe: Jesse Stephenson Jesse Stephenson 03/14/17 08:17PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/15/17 10:07PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/15/17 10:19PM
  Re: Metra 65 puch kit questionsRe: Ben Whittle Ben Whittle 03/15/17 10:56PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/21/17 09:32PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/21/17 09:40PM
  Re: Metra 65 puch kit questionsRe: David Conn David Conn 03/21/17 09:45PM
  Re: Metra 65 puch kit questionsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/21/17 09:56PM
  Re: Metra 65 puch kit questionsRe: Graham Motzing Graham Motzing 03/23/17 12:45AM
