KREIDLER: Mega Performance Thread
Doug Wilhelm /
I recently decided to get back into the moped game... with another Kreidler. This time, it's a grey MP-19 in rough shape:
After some love, I got the motor to run. However, it has air leaks and loud crankshaft bearings, and I decided to rebuild.
I have sourced parts and knowledge in the past, but this time I decided to share my knowledge in one place. There is actually a decent amount of info out there about the MP motor, but most of what I've found has been on foreign forums (difficult to translate properly).
I'll share what I know currently, and will post updates as some of my parts begin arriving in the mail.
Sprocket (in ya pocket)
I found two places where you can purchase sprockets for this motor; eBay Germany and Kreidlerparts.com:
- eBay Germany
- Kreidlerparts.com
eBay Germany listings are difficult to sort through, since the sprockets are not in great supply, and the listing titles are inconsistent. I ordered a 14t sprocket through this method; however, the Kreidlerparts website appears to also carry a 15t sprocket.
Cylinder
My research about a kit or aftermarket cylinder has been inconclusive. Some people have ported stock cylinders with moderate performance gains; I have never attempted porting on a Kreidler cylinder. Maarten's Kreidler Club had a few threads on aftermarket cylinders, and I did not find any additional info there; but more searching may reveal more info. Also, the MP motor has the same stroke as the Florette, however I believe the stud spacing is different.
Exhaust Pipe
I have owned two bikes now with a modified Vespa Proma Circuit pipe from Treats. This has significantly increased power of the bike. Essentially, the stock header had to be welded to the Vespa pipe and braced to prevent undue stress on the cylinder exhaust port.
- Vespa Proma Circuit
Piston Rings
According to Myron's mopeds, the Kreidler piston uses 40mm x 1.5mm GI (GI (grano interno) = center pin gap style) style rings. Treats actually carries several sets of rings in this size, but I have never tried them:
- Malossi Piston Ring
- Replacement Piston Ring Set
- Replacement Gilardoni Piston Ring
- Kreidlerparts.com Rings
Piston
Myron's Mopeds also carries various pistons for the MP motor. The thing to note is there were different sizes (noted by a letter stamped on the piston crown), so the cylinder you use must match the piston. For example, I have encountered several "H" and "D" and I think an "F" once. Kreidlerparts also sells aftermarket Zeta pistons:
- Myron's Mopeds Pistons
- Kreidlerparts Zeta Pistons
Crankshaft Bearings
Original crank bearings were FAG B015 bearings. These are hard to find, but I sourced several places to find them:
- Myron's Mopeds B015 Bearings
Amazon.com
- Draganfly 15x40x9 - the 9 might be 10. I ordered a set of these but have yet to see them in the mail.
- Related Google Search
Crankshaft Seals
The two crank seals are not listed on Treats, but there are several that would work if you had the Kreidler MP case holes for the seals widened. Here are the sizes:
- x1 - 15x24x7
- x1 - 15x25x5
I ordered some seals from sketchy eBay vendors (1 was for a Stihl chainsaw), and have yet to try them. "NEW GENUINE OEM STIHL Chainsaw 15x25x5mm Oil Seal 9639-003-1584 (96390031584)"
- Myron's Kreidler Crankshaft Seals
Clutch Removal Tool
Shelly from Minnesota did a great writeup on making your own clutch tool for under $5 of hardware store items. Here is the link:
- Kreidler Clutch Removal Tool
Gaskets
I have always made my own gaskets (except head gasket - and orangerobin tells me I can use thin copper for this) from Autozone grey gasket fiber / paper. But, I found a set of gaskets on eBay:
- eBay Gasket Set
Ignition
From what I've gathered, this bike uses the same ignition / stator as a Puch. Treats claims the HPI works on the MP motor, but I challenge someome to actually post a video on this.
- Treats Puch HPI
Additional Resources
- Shelly's Website - Kreidler
- Kreidlerparts.com
- Myron's Mopeds
- Maarten's Kreidler Club
- Moped and Scooter Strokes
- Moped Parts Crossover
Thanks and Mentions
To reach this level of knowledge, I had a lot of help through many, MANY people... however a few specifically related to Kreidler come to mind: the HnRz, Casserollers, Boot2TheHead, MA, and many various people who have helped me along the way. It was also Mike Biery that helped get me into the world of mopeds - and I am forever thankful.
  KREIDLER: Mega Performance ThreadTopic by: Doug Wilhelm Doug Wilhelm 03/07/17 02:32AM
  Re: KREIDLER: Mega Performance ThreadRe: grim ripper grim ripper 03/07/17 03:46AM
  Re: KREIDLER: Mega Performance ThreadRe: Dave & Bummerzz Dave & Bummerzz 03/07/17 09:32AM
  Re: KREIDLER: Mega Performance ThreadRe: river 2strokes river 2strokes 03/08/17 07:50AM
  Re: KREIDLER: Mega Performance ThreadRe: Boot 2Thehead Boot 2Thehead 03/08/17 02:29PM
  Re: KREIDLER: Mega Performance ThreadRe: Boot 2Thehead Boot 2Thehead 04/05/17 12:22PM
  Re: KREIDLER: Mega Performance ThreadRe: Born to be WillD Born to be WillD 04/07/17 02:23PM
  Re: KREIDLER: Mega Performance ThreadRe: Graham Motzing Graham Motzing 04/07/17 02:36PM
  Re: KREIDLER: Mega Performance ThreadRe: Doug Wilhelm Doug Wilhelm 10/26/17 03:38PM
  Re: KREIDLER: Mega Performance ThreadRe: Nick Smith Nick Smith 04/07/17 11:23PM
  Re: KREIDLER: Mega Performance ThreadRe: grim ripper grim ripper 04/10/17 03:46PM
  Re: KREIDLER: Mega Performance ThreadRe: Doug Wilhelm Doug Wilhelm 10/26/17 03:41PM
  Re: KREIDLER: Mega Performance ThreadRe: Glenn Kuehn Glenn Kuehn 10/26/17 07:58PM
  Re: KREIDLER: Mega Performance ThreadRe: Boot 2Thehead Boot 2Thehead 10/27/17 01:17PM
  Re: KREIDLER: Mega Performance ThreadRe: CTpEDsHED jOHNNYdOUBE CTpEDsHED jOHNNYdOUBE 11/03/17 07:22PM
  Re: KREIDLER: Mega Performance ThreadRe: - schmiddy - schmiddy 11/12/17 11:47AM
  Re: KREIDLER: Mega Performance ThreadRe: Matt Decker Matt Decker 11/13/17 08:54PM
  Re: KREIDLER: Mega Performance ThreadRe: greg b greg b 11/15/17 08:32PM
  Re: KREIDLER: Mega Performance ThreadRe: Glenn Kuehn Glenn Kuehn 11/19/17 04:46PM
  Re: KREIDLER: Mega Performance ThreadRe: Matt Decker Matt Decker 11/21/17 07:54PM
  Re: KREIDLER: Mega Performance ThreadRe: Glenn Kuehn Glenn Kuehn 11/21/17 10:09PM
  Re: KREIDLER: Mega Performance ThreadRe: CTpEDsHED jOHNNYdOUBE CTpEDsHED jOHNNYdOUBE 12/02/17 11:07PM
Click here to login.
