Puch Sabre build thread
Ben Whittle /
Starting this thread for anyone who wants to follow this and chime in with any helpful advice.
The Sabre was running but needed a rebuild due to its age and condition. I took the engine off and tore it down. I already had a LC Horizontal Minarelli kit
(Amazon link)
for scooters running 43mm stroker cranks that I intended to use on an e50 but never got around to. Going to add a plate to the top for a DIO manifold with kx65 reeds to allow case induction and a 24mm OKO.
-Both horizontal Minarelli and Sabre cranks are 85mm con rods.
-The minarelli cylinder has 3mm more deck on the bottom of the cylinder.
-Wrist pin heights are a few mm different so the piston sat 1mm below at tdc with gasket and spacer that came with the kit for adjusting squish.
I had a local machinist add some material behind the ignition side transfer, outer tips of the transfers and around the backside of one of the stud holes.
He also took 1.5mm off the deck and relocated the stud holes for the new top end while it was in the mill. Since the new stud holes slightle overlapped the old holes, beefy M8 ID threaded inserts will be used.
  Puch Sabre build threadTopic by: Ben Whittle Ben Whittle 01/28/17 03:18PM
  Re: Puch Sabre build threadRe: Jeremy Homser Jeremy Homser 01/28/17 03:36PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 01/28/17 05:55PM
  Re: Puch Sabre build threadRe: Clay Forrey Clay Forrey 01/28/17 06:10PM
  Re: Puch Sabre build threadRe: Senor Si Senor Si 01/28/17 10:28PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 01/29/17 05:45PM
  Re: Puch Sabre build threadRe: T y l e r T y l e r 01/29/17 06:13PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 01/29/17 09:28PM
  Re: Puch Sabre build threadRe: Daniel '' Daniel '' 01/29/17 10:14PM
  Re: Puch Sabre build threadRe: will warn will warn 01/30/17 10:34PM
  Re: Puch Sabre build threadRe: Daniel '' Daniel '' 01/31/17 02:19PM
  Re: Puch Sabre build threadRe: will warn will warn 01/31/17 05:19PM
  Re: Puch Sabre build threadRe: timothy rendall timothy rendall 02/03/17 05:17PM
  Re: Puch Sabre build threadRe: Ken Roff Ken Roff 02/03/17 10:05PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 01/29/17 10:23PM
  Re: Puch Sabre build threadRe: Ike Pipe Ike Pipe 01/29/17 10:26PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 01/30/17 12:39AM
  Re: Puch Sabre build threadRe: Daniel '' Daniel '' 01/30/17 01:17PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 01/30/17 05:23PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 01/30/17 10:03PM
  Re: Puch Sabre build threadRe: will warn will warn 01/31/17 05:24PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 01/31/17 07:10PM
  Re: Puch Sabre build threadRe: Dave & Bummerzz Dave & Bummerzz 02/01/17 02:22PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 02/02/17 11:49PM
  Re: Puch Sabre build threadRe: M-Tenn Aaron M-Tenn Aaron 02/03/17 05:55PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 02/03/17 08:20PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 02/05/17 11:20AM
  Re: Puch Sabre build threadRe: Daniel '' Daniel '' 02/07/17 04:45AM
  Re: Puch Sabre build threadRe: timothy rendall timothy rendall 02/07/17 01:52PM
  Re: Puch Sabre build threadRe: will warn will warn 02/07/17 09:15PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 02/07/17 09:57PM
  Re: Puch Sabre build threadRe: will warn will warn 02/08/17 02:15AM
  Re: Puch Sabre build threadRe: will warn will warn 02/21/17 11:45PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 03/30/17 10:46PM
  Re: Puch Sabre build threadRe: Johnnie Distefano Johnnie Distefano 03/31/17 12:11PM
  Re: Puch Sabre build threadRe: Johnnie Distefano Johnnie Distefano 03/31/17 12:12PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 11/21/17 07:38PM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 11/21/17 07:46PM
  Re: Puch Sabre build threadRe: Brandon Weiss (aka B-Man) Brandon Weiss (aka B-Man) 11/22/17 08:37AM
  Re: Puch Sabre build threadRe: Ben Whittle Ben Whittle 11/22/17 09:41AM
  Re: Puch Sabre build threadRe: Dave & Bummerzz Dave & Bummerzz 11/22/17 09:49AM
Click here to login.
