Re: Boost or boosts? Chop that garbage out test
♣Slew Foot♣ /
This is informative...
How does it translate to a case inducted .motor?
I have a few bat cyl s lay in around... Over square and half throw... One is at 42mm but the skirt is too thin.
It almost looks like a Heropuch WOP cyl you got going on there
All these are case reeded.
The issue is that if running substandard sized main and secondary transfers, any obstructions caused by individual separate boost ports actual restrict mix getting to the top. If the cases are set up for big ass transfers then you don't need to do this, but 90% of mopeds are not.. My mopeds rip hard with this addition to its multiple mods.
