Re: Could you rig up a needle valve?
Charles Cole (OFMC) /
What what would be really cool, is to have the valve solidly mounted as close to the carb as possible and have a device/adjuster at an easily accessible place, so you can adjust the valve similar to how the MotoGP guys adjust their front radial brake with their left hand while during a race or practice. Used in conjunction with a temp sensor, you could dial it in any time you need. And by the way, I think your idea is great!
Totally normal JBOT /
It might not perform right under load due to the long tubing.
Like it'll be fine on the stand but suck to ride.
The vacuum might not pull fuel as well with the restriction
Ike Pipe /
1ke OP
> long tubing.
> restriction
Well, I think you're basically right. Except, I'm getting the same performance and speed I was getting with the jets, minus a very slight lag. It hauls me up and down the block the same. Perhaps it will be different in warmer weather. We'll see what shorter tubes do. The one for my brother will be as short as it gets as I'll mount it directly to the float bowl.
@Charles Cole Your wish is granted. The needle valve I'm using is from O.S. Engines and has a set screw in the knob, and a hole in the end. Simply loosen the set screw, insert cable, and tighten set screw.
I didn't go this route because I was using just what I had lying around, and what one really nice guy sent me in the mail. I may end up getting there for the reason listed above. R/C airplanes have remote needle valves set up like this, but they are usually attached to the back of the engine and so are not far away from the carb.
Maybe something to try in the future.
Ike Pipe /
1ke OP
I moved the needle valve much closer, and I trimmed about 8 inches of tubing. I used a bit of plumber's pipe hanger strap to attach it to one of the float bowl screws.
No testing as it is dark and cold.....cold....cold. Maybe tomorrow night.
Ike Pipe /
1ke OP
OK, got a chance to get it out. The shorter tubing helped. Running awesome!
Good, how are temps?
Well, kinda hard to tell real working temps whenever its so cold out.
I ordered the traxxas part you linked out too...waiting on a nipple and I'll test this on a pbdg carb.
I'll post pics!
Ike Pipe /
1ke OP
That is an excellent question. I wish I had a way to answer. At the moment I have no practical way of answering. Could I touch a meat thermometer to the head and make that work?
The only thing I can tell for sure, is that it is running at least as well as it did with the jet. I let it sit for 6-8 minutes after starting 'cause someone wanted to talk to me. It ran fantastically. I then drove up and down the block for a good 10-15 minutes. If I was running lean, I'm pretty sure I would have started bogging down, right? Even at this air temperature, it would be over heating if I was too lean, right? Also wasn't going super slow or sluggish like I would expect if it was too rich. Also no major visible smoke coming out of the tailpipe.
I should have told you that it warmed up a lot today. It was probably 35-40 out there when I was riding. Supposed to be in the 50s tomorrow, so I'll go ride some more and see what happens.
Ike Pipe /
1ke OP
> pbdg carb.
> I'll post pics!
SSWWWEEETTTTT!!!!! I'll look forward to that. By the way, I did spring a leak with the vinyl gas line, so make sure you get something better.
Very cool! well done!
This is cool.
I wonder if you could use some of the tech that's used with the dial a jet stuff.
Have you seen their setup?
Ninja . Wrote:
> Just be glad you have a Bravo/Grande set up. To
> get to the jet on a Ciao you have to take off the
> one-speed clutch, loosen the three motor bolts
> shove the engine forward and get to the carb.
> Trust me after doing that 5 or 6 times you will be
> glad to have a Bravo. With my Grandes/Bravo I
> remove the bottom plate and BAM you’re in carb
> city remove the bowl and in like sin.
Wut. It takes me 5 seconds to pull my carb off on my ciao. Then I just pull the bowl and rejet.
I guess I’m not the only person to read in thread view haha
With a Grande/Bravo set up you don’t even need to remove the carb from being attached to the motor to rejet/upjet. (edited)
Just like Jbot, I highly recommend that Tygon tubing. Rather than just buy a little piece, I'll look for a roll on ebay. It's nice having it just laying around the shop when you need it.
Ike Pipe /
1ke OP
I did look at the dial-a-jet. Problem 1 is that it costs about as much as a whole fancy carb for a moped.
They do it weird, too. They tap the float bowl same as I do, but instead of replacing the jet, they pipe the gas into the venturi. I don't know exactly how it all works, and why it isn't just rich as crap with two fuel sources... They advertise that it can be installed without disassembling the carb.
They also say that they have five settings. I don't know if there is a way to get more variation out of it or not, but five settings, while an improvement over just jets, seems a bit limited for an add-on that costs $80. The mod I've presented costs under $20 and gives you infinite control.
I SHOULD asterisk here and point out that the $20 price tag is using that needle valve from Traaxas. The needle valve I have is more expensive and comes from OS Engines. The ONLY reason I have it is because my dad had a scrap one lying around. I do think the Traaxas one will work just as well, but I can't guarantee it. I plan to order one and install it on my brother's bike in the next month and then I can report back. Ponch got one and said he'd post pictures, so we'll get some good info there as well.
Tuning Notes:
R/C engine instructions tell you to open the needle valve about 3-4 turns for starting, throttle up to WOT, then close the valve 1/4 turn at a time until you peak RPM. This is the ideal mix. Once you pass it, the engine will slow again, and you'll be leaning out. I recommend finding your peak, then opening a little to the rich side as a cushion.
On my Bravo, with a completely stock 50cc engine, a bored out 13mm carb, and a basically stock exhaust, at 40 degrees F, my ideal setting was somewhere around 2.5 turns open. Keep track of these settings, and set the mix while running on the center stand. Once you set it, you should be able to just adjust each time you want to, and not start at the beginning.
@ Charles Cole
Picked up tygon tubing today, hope to install a little later tonight. :)
Are you thinking a power jet carb? A power jet OKO is pretty cheap.
I do really dig this though. I have a 28mm power jet oko on my bravo race bike, I'm gonna get one of those adjustable valve deals for the power jet for sure now! What was the one you are currently using? And in what ways is it nicer than the traxxas one?
This carb has the power jet to give it the juice straight in
This is really close to the same carb without the power jet hose and taps
Ike Pipe /
1ke OP
@ Tyler
The Traaxas needle is made for a smaller engine than the one I have. Bear in mind that many of the needle valves on smaller engines are also used on larger engines of the same brand. If you can have a look at them in real life, you could probably measure the orifices and see if there is a big size difference. I didn't think it mattered much when I started, and still don't, because the size of the orifices inside the carb (float needle hole and jet hole) are smaller than the orifices of the needle valve. You want to control the flow, not permanently restrict the flow. The jet I used was a 94, which should be bigger than just about any jet anyone will ever use on a moped, and the hole was still smaller than the needle valve orifices. Conclusion: I think pretty much any of the needle valves will work for this project.
The other difference is that one end of the Traaxas needle valve body is threaded. That's a good thing because you can drill a hole in the bowl, pop a rubber washer on the needle valve body, and screw it in. (The steel threads will cut into the soft aluminum easily.) You can mount the needle valve directly to the float bowl anywhere as long as you don't stop the movement of the float, and save yourself some effort trying to mount it elsewhere on the bike. On my Bravo, mounting directly to the bowl isn't an option because then I can't get to it. The OS valve body has two nipples instead, so I could just do what I did. I bet you could find a way to use the Traaxas one in the same way I did, if needed.
@ Scooter
How cheap is cheap? I'd be interested in such a thing later on.
That has lots of adjustments. The screw pointed up at an angle is the slide screw? Is that big black knob a mixture control? And the slotted screw on top of the power jet hose, what does that do?
It looks like a pretty awesome setup!
Ike Pipe /
1ke OP
Bummer note: Carb still leaks after switching to tygon. Gonna have to figure out how to seal it up.
If I didn't need to get into the bowl very often, I could solder it. I'd have to melt the solder before taking the bowl off, though. Would be tedious and painful, but it would work.
I'm open to suggestions!
Detail shot of the mount. Figured I'd share while it was out...
Now I'm thinking about it, when I drilled the holes in the bowl, I never chamfered them. Might not matter, but it may be that I gouged the tube with a sharp edge as I was installing. It was a quite tight fit, so it is possible. I'll investigate and check back.
I know you already purchased a needle valve but I found this on an RC site. Has mounting cast into it & only $10.
If you need a cylinder head temp gauge, there's plenty of ebay listings for under $40 for a Trail Tech. Together, you should be able to super dial it in.
http://www.amainhobbies.com/rc-airplanes/evolution-remote-needle-valve-assembly-tps4046-evo046874a/p33279
Ike Pipe /
1ke OP
I did get the bike to stop leaking.
Tygon is flexible and is supposed to stay that way over time, but it is not very stretchy. Vinyl, on the other hand, is more stretchy, but yellows and cracks with age. I want to get some neoprene and try that out as it is supposed to be pretty good, and Du-Bro makes it in the right size.
First thing I did was to shorten the jet tube. It now protrudes from the bottom of the bowl just 1/8 inch. I rounded the edge of the brass tube with a file to make sure of no burrs, and to help it slip into the tygon. I also chamfered the hole in the bowl by hand using a drill bit, just to be sure I wasn't cutting it.
Well, the tygon still leaked.
Looking back, when I thought the vinyl was leaking, I had a loose bowl screw from attaching the needle valve. I'd switched to tygon 'cause that was the better material, hoping it wouldn't leak. Well, it's lack of squish and stretch meant it wouldn't seal. For now, I have a splice. Most of the system is tygon, but a very short piece is vinyl, to seal it up.
I'll report back when I have a chance to try out some neoprene. In the mean time, it doesn't leak, and it works.
compression barb fitting modified like jbot suggested
Ike Pipe Wrote:
> @ Tyler
The thing about a carb with a powerjet is that there is still a main jet. So the powerjet is more of an auxiliary source of fuel at wot. So I don't mind restricting it down a bit, I'll just compensate on the main jet. Obviously my idea is not the same as your original project. Thanks for the info on the needles, although somewhat unrelated I might add my results to this thread to keep the needle valve info all in one thread if you don't mind.
Probably Fred /
Do you keep same line /fuel pressure? Pressurize tank? Fuel pump? Or just adjust needle on the fly when tank gets low?
Ike Pipe /
1ke OP
> when tank gets low?
I just left the rest of the bike alone. Gravity fed. As long as there is fuel, I should think the pressure would be the same. R/C stuff pressurizes the tank by piping some of the exhaust to it. Thought about playing with that, but I'll wait awhile before I do.
@tyler
I welcome anything you want to add! Good luck with your project. I am excited to see what you come up with!
Ike Pipe /
1ke OP
Found this grommet at the hardware store. It might be a good option for sealing up the bowl.
I'm getting good at making these.
I really want to try this with a race carb bowl, solder the pipe to the float bowl screw so swapping back to normal jets is no problem! How much more can you turn the dial out? Is there a way to lock the setting so it won't vibrate lean? Going to try this on a 70cc set up, our weather in Missouri is all over the place, you can tune one day and be good and the next no bueno.
