Re: Puch 3 shoe clutch
Probably Fred /
Daniel '' Wrote:
> i have 14x45 on my magnum and i am very pleased
> with it. check for air leaks if you are low on
> torque with that set-up the 64 puts out pretty
> decent mid range. Your clutch with that gearing
> and set-up should be locking up at about 20-25 for
> optimal performance. right around 5500-6000 rpms,
> which is about 25 lbs with the snordley method.
14x45 gears
I'm sure your not using stock crank or low rpm pipe
