Re: Honda Hobbit 70cc kit
Ryan . /
No, the Athena is A LOT larger than stock. Also, it has actually not too much to do with displacement as the cylinder even in a 50cc configuration would put out many times the power and heat as stock. The compression ratio is much higher and it is not an issue of machining. Most of us did it by hand with dremels and racquetballs for Christ's sake.
The stock kit does not HAVE a squish. Not one that can be used for reference anyway. See that is where you are giving me the impression of doing it wrong. You think you can measure all the stock parts and that'll be "ok" and it won't. 6.5:1 compression will require so much head material removed or so much spacing that you will not actually have a squish band and will be losing a huge part of the reason there is performance in general. In that case get the cheapest kit you can, because it isn't going to make dick for power anyway.
Forget about trying to modify what is there and consider it to be making something that never was. You need to know what a squish band is, how it functions and how you would like to make yours. Every one is different and every one will have different results.
  Honda Hobbit 70cc kitTopic by: Dayton Bourassa Dayton Bourassa 08/20/15 07:45PM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 08/20/15 08:50PM
  Re: Honda Hobbit 70cc kitRe: Aaron Bowen Aaron Bowen 08/20/15 09:57PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/20/15 09:04PM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 08/20/15 10:20PM
  Re: Honda Hobbit 70cc kitRe: Benjamin LaPlante Benjamin LaPlante 08/21/15 10:19AM
  Re: Honda Hobbit 70cc kitRe: Daniel Harney Daniel Harney 08/21/15 11:31AM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 08/21/15 12:24PM
  Re: Honda Hobbit 70cc kitRe: Daniel Harney Daniel Harney 08/21/15 12:51PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/21/15 01:44PM
  Re: Honda Hobbit 70cc kitRe: Daniel Harney Daniel Harney 08/21/15 04:46PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/21/15 04:52PM
  Re: Honda Hobbit 70cc kitRe: Daniel Harney Daniel Harney 08/21/15 04:59PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/21/15 05:00PM
  Re: Honda Hobbit 70cc kitRe: Daniel Harney Daniel Harney 08/21/15 05:27PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 08/21/15 08:23PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/21/15 09:00PM
  Re: Honda Hobbit 70cc kitRe: Travis Noll Travis Noll 08/22/15 02:47AM
  Re: Honda Hobbit 70cc kitRe: wilfrin hiciano wilfrin hiciano 08/22/15 12:02PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 08/22/15 12:45PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/22/15 12:45PM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 08/22/15 12:50PM
  Re: Honda Hobbit 70cc kitRe: wilfrin hiciano wilfrin hiciano 08/22/15 01:10PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 08/22/15 02:39PM
  Re: Honda Hobbit 70cc kitRe: wilfrin hiciano wilfrin hiciano 08/22/15 04:27PM
  Re: Honda Hobbit 70cc kitRe: Dirty30 Dillon Dirty30 Dillon 08/25/15 09:59AM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 08/22/15 02:57PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/22/15 03:09PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/22/15 06:31PM
  Re: Honda Hobbit 70cc kitRe: Daniel Harney Daniel Harney 08/23/15 12:53PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/23/15 05:51PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 08/23/15 11:04PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/23/15 11:16PM
  Re: Honda Hobbit 70cc kitRe: wilfrin hiciano wilfrin hiciano 08/24/15 05:43PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 08/24/15 11:04PM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 08/24/15 11:25PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/25/15 08:32AM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/25/15 11:39AM
  Re: Honda Hobbit 70cc kitRe: Born to be WillD Born to be WillD 08/25/15 12:00PM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 08/25/15 12:06PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/25/15 12:44PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 08/26/15 12:27AM
  Re: Honda Hobbit 70cc kitRe: wilfrin hiciano wilfrin hiciano 08/26/15 11:25AM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 08/26/15 11:38AM
  Re: Honda Hobbit 70cc kitRe: wilfrin hiciano wilfrin hiciano 08/26/15 11:31PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/26/15 04:56PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 08/26/15 10:15PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 08/26/15 10:21PM
  Re: Honda Hobbit 70cc kitRe: Daniel Harney Daniel Harney 09/04/15 11:19PM
  Re: Honda Hobbit 70cc kitRe: Will Parrish Will Parrish 09/05/15 04:57AM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 09/05/15 11:01AM
  Re: Honda Hobbit 70cc kitRe: Will Parrish Will Parrish 09/06/15 11:46AM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 09/06/15 12:24PM
  Re: Honda Hobbit 70cc kitRe: Will Parrish Will Parrish 09/06/15 11:10PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 09/09/15 03:50PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 09/09/15 03:54PM
  Re: Honda Hobbit 70cc kitRe: Dirty30 Dillon Dirty30 Dillon 09/09/15 04:00PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 09/09/15 04:00PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 09/09/15 04:13PM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 09/09/15 05:05PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 09/09/15 05:18PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 09/09/15 08:39PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 09/09/15 09:53PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 09/09/15 10:10PM
  Re: Honda Hobbit 70cc kitRe: C Garner C Garner 10/30/15 09:07PM
  Re: Honda Hobbit 70cc kitRe: Dayton Bourassa Dayton Bourassa 09/26/15 07:11PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 09/26/15 08:55PM
  Re: Honda Hobbit 70cc kitRe: Jim Adelberg Jim Adelberg 09/26/15 10:40PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 09/27/15 11:09AM
  Re: Honda Hobbit 70cc kitRe: JBOT Admin JBOT Admin 09/27/15 09:21PM
  Re: Honda Hobbit 70cc kitRe: Charles Cole (OFMC) Charles Cole (OFMC) 09/28/15 01:17AM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 10/31/15 03:09PM
  Re: Honda Hobbit 70cc kitRe: C Garner C Garner 10/31/15 04:17PM
  Re: Honda Hobbit 70cc kitRe: Ryan . Ryan . 10/31/15 06:29PM
  Re: Honda Hobbit 70cc kitRe: Jack Rutherford Jack Rutherford 05/18/19 09:41AM
