qt50/yt60 help
recently put a yt60 cylinder on my qt50
here are the specs
OEM used yt60 cylinder with low miles rebored and cross hatched
NEW oem Yamaha piston and rings
new piston clips and gaskets (also oem from Yamaha)
oem yt60 main jet (92.5)
brand new unipod filter
needle set too the second from leanest position, (stock setting)
180psi of compression
starts first try everytry
runs GREAT! idles smooth, great power
only thing is, runs too rich, it will sputter at 30mph, no uni-pod it"ll do 40mph, but I wanna keep a filter on it
what have other people ran as far as jetting and filtration?
I have no issues with the way it runs, I just don't wanna drive it open carb, I guess ill go down too a 90 jet? and try that with the uni-pod? idk
I thought the stock yt60 came with a 92.5 and the same vm12 carb, why would it need smaller jetting? little confused but oh well
Re: qt50/yt60 help
Steve Vitale /
also its running a stock exhaust, that could be part of the too rich problem
Re: qt50/yt60 help
Adjust the needle.
Re: qt50/yt60 help
Also, stop making new threads. Bump your last one since it's still on the first page.
Re: qt50/yt60 help
Ben Whittle Wrote:
> Adjust the needle.
Re: qt50/yt60 help
Steve Vitale /
true, thanks, its at second leanest setting, ill try the leanest and if not ill go buy a smaller jet thanks
Re: qt50/yt60 help
Steve Vitale /
what have other people ran as far as jetting with a stock yt60 setup?
Re: qt50/yt60 help
Steve Vitale /
too anyone else who needs help with this. the standard jet is a 92.5 but this is too rich for a filter, if you wish to run a unipod or OEM airbox the jet you should be running is an 85 for maximum performance, courteous of Yamaha service bulliton
Re: qt50/yt60 help
Steve Vitale /
got too tuning today, MY best results were 82.5main jet, stock 40 pilot, needle set too the second from highest notch, and I gps'd 42mph, stock everything except the yt60 cylinder kit and main jet and unipod filter. next step is pw50 gears. ;)
Re: qt50/yt60 help
Let me know where you find any decently priced pw50 gears, the ones listed on ebay are over $100. I can't find them anywhere else.
Re: qt50/yt60 help
Steve Vitale /
I havnt tried looking yet, just posted on here in the buy/sell section
Re: qt50/yt60 help
