New to me 2001 Tomos arrow...questions
Hey guys
I scored a sweet 2001 Tomos arrow on the cheap. The po made some kids but didn't do it right , here's my issue.
Added a technigas exhaust. Didn't upjet the stock dellarto carb or air intake. Runs like crap.
Can I get some advice on the proper setup needed for this exhaust? Looking for proper jets to run, proper air etc... Trying to get to know this thing and have some fun.
Thanks in advance!!
Re: New to me 2001 Tomos arrow...questions
Probably Fred /
If you don't up jet you're going to seize and you could have done some scoring damage as it is .
Around 61 jet with black plastic cap and screen filter and performance pipe but you're probably using stock airbox so could be less
Get like 56-62 jet range of jets
Do not run your bike until you up jet it
Shaun Ruudz /
Yup I haven't took it out for a burn because I noticed the problem. Any type of air filter/intake recommended?
Been told to look for a 60 jet? Should just the main be changed or should all of them be done? I've already taken apart the carb and completely cleaned it.
Probably Fred /
> cleaned it.
Yes like I said the black plastic cap with a screen filter that fits into the sha is best.
It takes around 61 jet.
Shaun Ruudz /
Here's some pics of the current setup
Have no idea what's stock, unknown the carb is.
I know a few of you have suggested proper air filter Etc, if you wouldn't mind providing a brand or link? I know these parts you have to buy all online and I want to buy the right ones obviously.
You probably have an air leak somewhere with all of them clamps.
Shaun Ruudz /
Probably yup, it's def getting too Much air.... I'm guessing that filter isn't stock.
Why do people just throw shit together makes no sense
Probably Fred /
What year arrow is that ?
What engine?
That carb is a phva that comes on a a55 engine not a35 engine
Takes 6 mm Dellorto jets
A 60-64 jet size should work but if a a35 reed valve engine it may take bigger then that. (edited)
Shaun Ruudz /
Its a 2001 with an a55
Fuck me I thought it was a dellarto carb
Should I be making any mods to this airbox or filter?
Shaun Ruudz /
Haha whoops don't mind what I wrote about the carb
Well I've got the jets lined up just need to figure out what tondo with the airbox and what not and get parts ordered
Probably Fred /
> carb
Did you get The bigger Dellorto Jets the ones that fit a phva?
Shaun Ruudz /
That's correct sir
Just don't know if I have the correct air filter on here
Been reading about people drilling a hole into their airbox?
Lots to learn about timing apparently the tomos is all about timing eh!
Probably Fred /
That filter is fine
I'm A newbie here, I have an A55 2012 Tomos Sprint, recently changed my stock pipe to biturbo and up jetted only the stock 55 main jet to a 58, bike running great so far added 5-7 mph... Tomorrow will try a 60 jet... Although new here, I definitely learned a lot from some knowledgable persons here and one thing that comes up over and over in order Not to seize engine is : if you change pipe u MUST UPJET! Hope that helps ...
