Re: Peugeot 12V DC Project
🇮🇹💦 Of the Loin /
Go back to your 16v AC setup, don't use the Honda reg rec.
16v on your meter is RMS, so you're actually peaking at about 21v AC. I had a similar issue to yours when I put a regulator on the AC side of the circuit and not the DC.
Let your unregulated AC flow into the rectifier (I use a bridge rectifier off the shelf from Radioshack rated 250v 50 amps or similar ), you can also build your own with 4 rated diodes of say 10a (HPI generates about 5A DC on the lighting coil).
Then send it from the rectifier to a filter/resevoir capacitor somewhere between 1000 and 4700 uf. I'm using 2200, but when I charge my phone my DC voltage sags from 12.7 to 11.4 so I might step it up.
After the cap, send it to a regulator,noff the shelf or otherwise. I built my own, but you can find a not rectifying regulator easy too.
And then boom, stable clean DC even at idle with no battery
  Peugeot 12V DC ProjectTopic by: Mikey Antonakakis Mikey Antonakakis 04/25/15 04:30PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/25/15 05:14PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/25/15 06:11PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/26/15 01:49PM
  Re: Peugeot 12V DC ProjectRe: M-Tenn Aaron M-Tenn Aaron 04/26/15 02:53PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/26/15 06:29PM
  Re: Peugeot 12V DC ProjectRe: kenny s kenny s 05/26/20 05:12AM
  Re: Peugeot 12V DC ProjectRe: P D P D 05/26/20 10:32AM
  Re: Peugeot 12V DC ProjectRe: Ryan Graeme Ryan Graeme 05/26/20 01:45PM
  Re: Peugeot 12V DC ProjectRe: b to the eff b to the eff 05/26/20 05:23PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/27/15 01:24AM
  Re: Peugeot 12V DC ProjectRe: Graham Motzing Graham Motzing 04/27/15 12:21PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/28/15 12:14AM
  Re: Peugeot 12V DC ProjectRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 04/28/15 11:02AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/28/15 12:02PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/30/15 03:12AM
  Re: Peugeot 12V DC ProjectRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 05/01/15 01:23AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 06/25/15 01:51AM
  Re: Peugeot 12V DC ProjectRe: b to the eff b to the eff 05/19/20 09:55AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 05/01/15 12:05AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 05/01/15 12:13AM
  Re: Peugeot 12V DC ProjectRe: M-Tenn Aaron M-Tenn Aaron 06/25/15 07:49AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 06/25/15 03:31PM
