Peugeot 12V DC Project
Mikey Antonakakis /
So, for some time, I've been wanting to properly set up 12V DC power on my Peugeot. I'm using a 5-coil stator with CDI, and the 12V DC would be nice for a water pump, or any other fun things (cool horn??).
I noticed that each of the posts on that stator is oriented at 60 degrees, so I thought I would be able to set up a nice 3-phase system like all modern Hondas use. This would mean I could use a nice, reliable Honda regulator/rectifier.
So, I rewound the coils to make 3 equal coils. I busted out the Dremel to move the ignition coil over to let me orient my power coils at 120deg.
At first, I tried a "wye" setup, with the neutral grounded to the stator plate/frame. With this, I had a nice strong 16VAC open-circuit measurement from ground to each phase. Due to the 120deg orientation of the coils, and the 4-pole magnet of the flywheel, this should have given a nice, evenly-spaced 3-phase system. But after connecting the regulator/rectifier, I had only a few volts DC coming out. It could be that I have a bad regulator/rectifier, but I decided to double check some Honda wiring diagrams. Seems like they all either use wye with a floating neutral (not grounded to frame) or delta.
So I disconnected neutral from ground, and checked the AC voltage across two of the three coil leads -- 2VAC :(
Then I tried delta configuration, with a similar result.
Does anyone know what I'm missing? It is something to do with only having 3 coils, each wrapped in the same direction?
  Peugeot 12V DC ProjectTopic by: Mikey Antonakakis Mikey Antonakakis 04/25/15 04:30PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/25/15 05:14PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/25/15 06:11PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/26/15 01:49PM
  Re: Peugeot 12V DC ProjectRe: M-Tenn Aaron M-Tenn Aaron 04/26/15 02:53PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/26/15 06:29PM
  Re: Peugeot 12V DC ProjectRe: kenny s kenny s 05/26/20 05:12AM
  Re: Peugeot 12V DC ProjectRe: P D P D 05/26/20 10:32AM
  Re: Peugeot 12V DC ProjectRe: Ryan Graeme Ryan Graeme 05/26/20 01:45PM
  Re: Peugeot 12V DC ProjectRe: b to the eff b to the eff 05/26/20 05:23PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/27/15 01:24AM
  Re: Peugeot 12V DC ProjectRe: Graham Motzing Graham Motzing 04/27/15 12:21PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/28/15 12:14AM
  Re: Peugeot 12V DC ProjectRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 04/28/15 11:02AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/28/15 12:02PM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 04/30/15 03:12AM
  Re: Peugeot 12V DC ProjectRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 05/01/15 01:23AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 06/25/15 01:51AM
  Re: Peugeot 12V DC ProjectRe: b to the eff b to the eff 05/19/20 09:55AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 05/01/15 12:05AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 05/01/15 12:13AM
  Re: Peugeot 12V DC ProjectRe: M-Tenn Aaron M-Tenn Aaron 06/25/15 07:49AM
  Re: Peugeot 12V DC ProjectRe: Mikey Antonakakis Mikey Antonakakis 06/25/15 03:31PM
