variated tomos a52
Frank Holvick /
Ive never made a build thread before, but I've decided that this might be worthy of documenting since as far as i know the only other variated tomos engine powered moped was built by tomahawk tuning. The only info i can find on the tomahawk bike was a pic and a few sentences describing it. Im not super far along with the bike, but this is the what i have planned. Its going to be powered by a modified tomos a52 engine and ill be putting that into the 81 (le moped) i just snagged of of craigslist.
I was originally going to modify my batavus regency roller i have, but the moby is a much better choice for a chassis for a lot of reasons. Im planning on using as many off the shelf parts as i can and keep machining and welding down to a min. i dont have pics of all of the destruction, but i started out by taking most of the transmission components out of the engine. i split the cases pulled the crankshaft and drive axle and then started trimming the case halves down lol
i started by cutting the engine in half, after it was a more manageable size i used a drill press to make a series of holes around the crankcase to remove as much material as i could before i started carving it down with the dremel and a hss burr.
  variated tomos a52Topic by: Frank Holvick Frank Holvick 04/16/15 02:42AM
  Re: variated tomos a52Re: Frank Holvick Frank Holvick 04/16/15 03:39AM
  Re: variated tomos a52Re: Chris Straub Chris Straub 04/16/15 04:02AM
  Re: variated tomos a52Re: Alex Degnes Alex Degnes 04/16/15 04:26AM
  Re: variated tomos a52Re: Frank Holvick Frank Holvick 04/16/15 01:14PM
  Re: variated tomos a52Re: T y l e r T y l e r 04/16/15 02:28PM
  Re: variated tomos a52Re: Max Johnson Max Johnson 06/21/15 12:57PM
  Re: variated tomos a52Re: Corporate Image Corporate Image 09/24/15 02:01PM
  Re: variated tomos a52Re: Max Johnson Max Johnson 09/24/15 03:37PM
  Re: variated tomos a52Re: Frank Holvick Frank Holvick 04/16/15 03:14PM
  Re: variated tomos a52Re: Graham Motzing Graham Motzing 04/16/15 03:56PM
  Re: variated tomos a52Re: Born to be WillD Born to be WillD 04/16/15 04:09PM
  Re: variated tomos a52Re: Born to be WillD Born to be WillD 04/16/15 03:33PM
  Re: variated tomos a52Re: Frank Holvick Frank Holvick 04/16/15 04:19PM
  Re: variated tomos a52Re: Frank Holvick Frank Holvick 06/22/15 02:29AM
  Re: variated tomos a52Re: Max Johnson Max Johnson 06/22/15 09:14AM
  Re: variated tomos a52Re: Josiah McCoy Josiah McCoy 06/23/15 08:34PM
  Re: variated tomos a52Re: Cody H Cody H 09/30/15 03:50PM
  Re: variated tomos a52Re: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/20/19 05:42PM
  Re: variated tomos a52Re: Lazy Pedaler Lazy Pedaler 10/31/19 01:52PM
  Re: variated tomos a52Re: todd amundson todd amundson 10/31/19 02:58PM
