Re: Diaphragm Type Carbs?
Alex Degnes /
Flagrant - Wrote:
> Local experience is that if the rpm range you are
> using is not too wide you are OK. Float carbs
> themselves could use a fourth jet for the very
> highest rpms and expansion pipe effect
I represent to you; The Powerjet!
Even better with a solenoid in the line - shut it off past peak to maintain the correct afr when the pipe starts working against you and the transfer port time-area is getting insufficient. (edited)
  Diaphragm Type Carbs?Topic by: Moby Dick Moby Dick 02/24/15 09:33AM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 09:40AM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/24/15 11:24AM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/24/15 12:01PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 01:11PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/24/15 02:29PM
  Re: Diaphragm Type Carbs?Re: Jason Grimm Jason Grimm 02/24/15 03:47PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 04:06PM
  Re: Diaphragm Type Carbs?Re: Derek Stahl Derek Stahl 02/24/15 04:04PM
  Re: Diaphragm Type Carbs?Re: Born to be WillD Born to be WillD 02/24/15 05:36PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 07:02PM
  Re: Diaphragm Type Carbs?Re: Born to be WillD Born to be WillD 02/25/15 02:41PM
  Re: Diaphragm Type Carbs?Re: Jason Grimm Jason Grimm 02/25/15 10:13PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/25/15 11:11PM
  Re: Diaphragm Type Carbs?Re: Jason Grimm Jason Grimm 02/26/15 06:46PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/26/15 09:30PM
  Re: Diaphragm Type Carbs?Re: Born to be WillD Born to be WillD 02/24/15 05:45PM
  Re: Diaphragm Type Carbs?Re: peter heid peter heid 02/24/15 07:08PM
  Re: Diaphragm Type Carbs?Re: Rebel Moby Rebel Moby 02/24/15 10:23PM
  Re: Diaphragm Type Carbs?Re: Giovanni Giarratana Giovanni Giarratana 02/24/15 10:40PM
  Re: Diaphragm Type Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 02/24/15 11:36PM
  Re: Diaphragm Type Carbs?Re: John Joedicke John Joedicke 02/25/15 07:27AM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/25/15 08:41AM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/25/15 12:32PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 12:37PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/25/15 02:13PM
  Re: Diaphragm Type Carbs?Re: Giovanni Giarratana Giovanni Giarratana 02/25/15 01:13PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 01:22PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/25/15 01:33PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 04:23PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 04:36PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 05:37PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 05:38PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/25/15 06:52PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 07:24PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 07:44PM
  Re: Diaphragm Type Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 02/25/15 08:02PM
  Re: Diaphragm Type Carbs?Re: Giovanni Giarratana Giovanni Giarratana 02/25/15 09:27PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 09:50PM
