Re: Diaphragm Type Carbs?
Giovanni Giarratana /
I currently run them on all my peds check out their site for proper CC sizing, I run an HL 141 carb from tillotson, runs so smooth when you have it tuned right, which isn't hard, just doesn't seem to have the torque like a vm18 has, but it could be because the carb was a little to big and maybe coupled with a smaller intake manifold like 18mm intake it would gain back some of the low end torque, thing spools up so fast,
**Also you don't need to tap into the case for signal, if your carb has a nipple type signal feed, then you can weld a nipple to your intake and connect a small rubber fuel line tubing
Some have a signal hole on the flange where you would bolt up to the intake, again you only need signal so if you grind a little pathway from the signal hole to the flow of the intake then that is enough, I'd post pics but never took any, I can this week if anyone is interested let me know
Look at the little hole on the attachment, all you need on a 1/4 inch plate flange is a little path to this hole to recieve signal/vacuum to power the pump
  Diaphragm Type Carbs?Topic by: Moby Dick Moby Dick 02/24/15 09:33AM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 09:40AM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/24/15 11:24AM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/24/15 12:01PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 01:11PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/24/15 02:29PM
  Re: Diaphragm Type Carbs?Re: Jason Grimm Jason Grimm 02/24/15 03:47PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 04:06PM
  Re: Diaphragm Type Carbs?Re: Derek Stahl Derek Stahl 02/24/15 04:04PM
  Re: Diaphragm Type Carbs?Re: Born to be WillD Born to be WillD 02/24/15 05:36PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 07:02PM
  Re: Diaphragm Type Carbs?Re: Born to be WillD Born to be WillD 02/25/15 02:41PM
  Re: Diaphragm Type Carbs?Re: Jason Grimm Jason Grimm 02/25/15 10:13PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/25/15 11:11PM
  Re: Diaphragm Type Carbs?Re: Jason Grimm Jason Grimm 02/26/15 06:46PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/26/15 09:30PM
  Re: Diaphragm Type Carbs?Re: Born to be WillD Born to be WillD 02/24/15 05:45PM
  Re: Diaphragm Type Carbs?Re: peter heid peter heid 02/24/15 07:08PM
  Re: Diaphragm Type Carbs?Re: Rebel Moby Rebel Moby 02/24/15 10:23PM
  Re: Diaphragm Type Carbs?Re: Giovanni Giarratana Giovanni Giarratana 02/24/15 10:40PM
  Re: Diaphragm Type Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 02/24/15 11:36PM
  Re: Diaphragm Type Carbs?Re: John Joedicke John Joedicke 02/25/15 07:27AM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/25/15 08:41AM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/25/15 12:32PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 12:37PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/25/15 02:13PM
  Re: Diaphragm Type Carbs?Re: Giovanni Giarratana Giovanni Giarratana 02/25/15 01:13PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 01:22PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/25/15 01:33PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 04:23PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 04:36PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 05:37PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 05:38PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/25/15 06:52PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 07:24PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 07:44PM
  Re: Diaphragm Type Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 02/25/15 08:02PM
  Re: Diaphragm Type Carbs?Re: Giovanni Giarratana Giovanni Giarratana 02/25/15 09:27PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 09:50PM
