Re: Diaphragm Type Carbs?
Born to be WillD /
maybe this help? basically the fuel level is always perpendicular to g-forces
g force on kart when turning pushes fuel to sides of carb
but with bikes, the carb leans with bike, and fuel's always properly in the float bowl.
that's why they use diaphragm carbs in karting, or like chainsaws n RC planes where you're moving the thing around alot.
not that you can't use a diaphragm on a ped tho. I had a murray that came with a tilotson rigged onto it. it worked but not as well as a proper carb... (edited)
  Diaphragm Type Carbs?Topic by: Moby Dick Moby Dick 02/24/15 09:33AM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 09:40AM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/24/15 11:24AM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/24/15 12:01PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 01:11PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/24/15 02:29PM
  Re: Diaphragm Type Carbs?Re: Jason Grimm Jason Grimm 02/24/15 03:47PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 04:06PM
  Re: Diaphragm Type Carbs?Re: Derek Stahl Derek Stahl 02/24/15 04:04PM
  Re: Diaphragm Type Carbs?Re: Born to be WillD Born to be WillD 02/24/15 05:36PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/24/15 07:02PM
  Re: Diaphragm Type Carbs?Re: Born to be WillD Born to be WillD 02/25/15 02:41PM
  Re: Diaphragm Type Carbs?Re: Jason Grimm Jason Grimm 02/25/15 10:13PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/25/15 11:11PM
  Re: Diaphragm Type Carbs?Re: Jason Grimm Jason Grimm 02/26/15 06:46PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/26/15 09:30PM
  Re: Diaphragm Type Carbs?Re: Born to be WillD Born to be WillD 02/24/15 05:45PM
  Re: Diaphragm Type Carbs?Re: peter heid peter heid 02/24/15 07:08PM
  Re: Diaphragm Type Carbs?Re: Rebel Moby Rebel Moby 02/24/15 10:23PM
  Re: Diaphragm Type Carbs?Re: Giovanni Giarratana Giovanni Giarratana 02/24/15 10:40PM
  Re: Diaphragm Type Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 02/24/15 11:36PM
  Re: Diaphragm Type Carbs?Re: John Joedicke John Joedicke 02/25/15 07:27AM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/25/15 08:41AM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/25/15 12:32PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 12:37PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/25/15 02:13PM
  Re: Diaphragm Type Carbs?Re: Giovanni Giarratana Giovanni Giarratana 02/25/15 01:13PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 01:22PM
  Re: Diaphragm Type Carbs?Re: Flagrant - Flagrant - 02/25/15 01:33PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 04:23PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 04:36PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 05:37PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 05:38PM
  Re: Diaphragm Type Carbs?Re: Moby Dick Moby Dick 02/25/15 06:52PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 07:24PM
  Re: Diaphragm Type Carbs?Re: Alex Degnes Alex Degnes 02/25/15 07:44PM
  Re: Diaphragm Type Carbs?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 02/25/15 08:02PM
  Re: Diaphragm Type Carbs?Re: Giovanni Giarratana Giovanni Giarratana 02/25/15 09:27PM
  Re: Diaphragm Type Carbs?Re: Jonathan Eaton Jonathan Eaton 02/25/15 09:50PM
