Interesting puch swingarms?
Totally normal JBOT /
Has anyone adapted other bikes swingarms to puch mopeds?
I'd like to see some cool examples.
Going to maybe adapt a dirtbike swingarm onto my pinto for fun.
Re: Interesting puch swingarms?
Probably Fred /
Not custom swingarm but a Murray swingarm is a good bolt on upgrade to a pinto/tube frame even a maxi though you will have to mod the rear fender.
3 inch tire fits depending on style and orientation
It's easier to adjust/center the rear wheel because it's more symmetrical then a magnum swingarm
Of course a magnum swingarm is good upgrade too
Think i remember seeing one bolted through the pedal tube/swingarm mount some years ago, it was like an alu dirt bike arm or something. (edited)
Korados are like that
Charles Cole (OFMC) /
It looks like a Murray swing arm, that was 'boxed in', would be very strong.
A friend of mine is getting a bunch of EBR swingarms in soon.
Probably Fred /
Believe me it's fine as it is. Way better then a maxi, cobra or pinto swingarm
I've got a Murray swing arm that has been filled in with 18ga steel plate to make it more "boxy". I haven't run it yet, but I anticipate a more stable swing arm, as the stock one had some noticeable flex going on. Jackerz! sold it to me at the end of 2013. At this rate, the bike may be together next year!
JBOT,
I have wondered who and when someone will weld up a beefy aluminum one like modern super bikes have.
Puchshop, 3 years ago.
Spencer Jacobson /
I put an mb5 swing arm on a maxi long time ago using the pedal crank hole.
Hey Spencer, did you modify that mb5 swing arm? The older ones ('82) look like it could bolt up through the pedal crank.
-Scheming and dreaming in Northern Michigan
Examples:...pics...pics...pics...
