Re: Derbi metrakit porting
Downhill Harvey (OFMC) /
Just another method in regards to derbi decomp plugs, the valve hole can be tapped without predrilling to M5x0.8
I picked up a set of M5 aluminum countersunk allen head screws from
OPPracing
and just threaded it in with a bit of loctite... no leaks
I think the aluminum screw will help to avoid hot spots in the chamber, you might be able to run slightly leaner??
Dirty30 Dillon /
That's tight ^^^ Exactly what I need to do to run a derbi head on my hobbit
So Boyz feast us eyes on this. Max originally worked in this derby metra kit head for me but lost access to his machine shop. Anyway Nate the great did this for me and naturally it's innovative. So that's a one way bearing he installed in the clutch so obviating the need for a decompression. Plus the head wasn't machined art the way to the Athena 47.6 width. He tigged dat decomp to oblivion before reshaping the head on his lathe.
Yea I want to one day be able to do stuff like this. This is exquisite as is cheeta 's pull stsrts. This one way valve should spin the crank forward and otherwise disengage. Definitely worth a trial!!! I gotta get to work on this stuff but I swore I would do those vespa engines first.
on my "race" derb I have found a stock decompless head from some PP/PR bike and had Lucky mill it to Puch Gila Squish specs. Makes a perfect .95mm squish with a 1mm base gasket. Ports dead on at BDC and with a little porting an ex duration right at 185º
the stock heads that didn't have a decomp, to my knowledge, were used on the start3/start5 motors. that's the only time i've ever seen them --- but maybe they were used on others? interested in finding out!
this is a cool thread. I just slapped a 47mm airsal kit on my variant yesterday. I cut the boost ports into the piston, cleaned up the casting a little, gapped the rings and spaced the kit appropriately and have amazing power. great for riding around the city. flew down claiborne last night passing cars. weeeeeeeeeeeeeee!
Cut her up last night, carbide bit on a dremel eats right through the piston, done in 5 min.
grim ripper /
my decomp is lapped and i'm not making any "extra" compression. it doesn't leak now...i freakin like decomp! is it going to blow up my shit? i lapped it good with proper valve lap compound...
i'm running a 12.12, it's fine right?
like if i put the destroyer and a 18+mm carb, maybe i'll get a no decomp head...
> finding out!
38mm squish so idk, not start 3 or 5
damn dan i was looking at a couple of my reed kits the other day and decided to port out the piston window to match the width of the port. then i was thinking...why the hell cant i just cut out the whole thing? thank you for the confirm here good shit
grim ripper /
it's the "puch polini" of '17.
Bump this to remember to read up when I get the derb out of storage and on the bench
never forget
^that's almost exactly what I've done with good results. My exhausts aren't quite that wide though
Dirty30 Dillon /
> a decompression.
I've seen this in action and it does work, but it definitely doesn't eliminate the need for decomp. You are still have to spin the motor by turning the wheels, just like starting with starter clutchs.
> for
> > a decompression.
> clutchs.
It does because you don't have starter shoes that will slip. If you belt angle is right, and gripping correct, you do NOT need a decomp.
Not sure if I initially wrote it correctly but yes the Nate one way bearing does work well. It requires some omnipresent belt tension so The belt actually will spin the crank. Also if the bike sits for a while the minute oil on between the bore and the rings probably dissapates making it hard to spin the engine. Two ways to deal with that
1 back out plug and spin for a bit with pedalling. Make sure if u have the plug out the kill switch is on so as to not fry your CDI.
2 haven't tried this seeing I have a cover over the magneto but spinning that by hand a bit should also work.
Which bearing? There's a ball bearing, and a needle bearing in the clutch bell.
There is a recent t post on methods to make this. I didn't fab it so I can't say exactly how Nate did the one way bearing. Pedaling directly rotates the crank and it disengages the pedal mechanism when not pedalling
Not a Metrakit, but fun to watch anyway,
Derbi metrakit 70cc on a morini m1....modified
Bump....I have a 65cc cast iron Metra for a Derbi Pyramid reed engine, and the 47mm airsal for my flatreed variant.
The 65 Metra has a 3rd transfer, but neither the piston or cylinder skirt are windowed.
How would I figure out how to make a window in the cylinder skirt in the proper place?
And for the 47 airsal, the cylinder skirt has windows, but not the piston. Figuring out the location of the piston windows is simple, just match em up at BDC. BUT, I see some people here cut away the whole piston skirt, without leaving a bridge at the bottom. Is that safe? I'd be worried about those prongs breaking off the piston.
Ummmm. Don't you see that everyone is doing it? Must be safe. Everyone is running it like that
Have any of you guys ran closed end wrist pins? I added auxiliary ports on my puch polini and it seems like if I sent them any wider the mix would go out the transfer and into the auxiliary exhaust ports thru the wrist pin hole before the blowdown period is complete.
Tommy isn't as much of an asshole as he sounds on the internet.
