Hello guys, greatings from Norway.
Here is my experience with stiffer spring in a rear Camino pulley:
I use the lowermost spring on the picture, this is the strongest spring i could get hold of that would fit.
I bought my springs here:
http://www.industrial-springs.com/
If you buy it elsewhere, you can use compression strength showed in picture above, and find the exact spring.
I had to grind a little bit to make it fit inside nr 15 on this picture:
I use 40,1 gram weights in total.
The moped is really nice an smooth now. I love it.
Its accelerate smooth all the way up to top speed with a stable torque.
The best is that it even accelerate nice up hills. Before when it was down shifting
it was really difficult uphills, because I was loosing the powerband when downshifting and it would go slower
because of this. Now i can loosen the throttle push it again and go straight up to the best powerband
No downshifting.
This setup is highly recommended for all of you guys with TJT vario and the new type (EU style, camino or what ever you call it) rear vario.
:D :D :D :D :D
I just want to add on that my camino is tuned with a light setup.
65 cc, proma exhaust, TJT vario, new rear spring and a small upjet. (edited)
