Chamber pipes for minarelli v1
Blorp Blorpmonger /
I'm looking for a chamber pipe for the V1 that is $100 or under. Searching the forums I am seeing pipes that probably aren't around anymore.
I am seeing pipes on treats that are up in the $250 range. Way to pricy for me.
Also, not sure which pipes are compatible with the v1.
Suggestions?
Re: Chamber pipes for minarelli v1
I think a tomos pipe would work with a little header hacking.
Blorp Blorpmonger /
Yeah, I was hoping for a bolt-on. Fabricating a bracket is fine, but I dont want to go drilling the core.
Slip on chamber? Uses the original header and clamps on
Tomos estoril pipes just take a little Dremeling to the flange long brass nuts on the studs and a little heat bend to kick it down a couple inches so the brackets line up. Then just pop a hole in the pipe mount where it wants to be, might need to make a spacer or bracket depending on how close you can get it bending and what bike it's for.
Blorp Blorpmonger /
Now I am googling 'slip on chamber', not sure what I am looking at.
Puch Estoril.
Widen the flange holes.
No header bending required.
It kicks the pipe to the chain side.
Figure out a way to mount it and you're solid.
simon thokaar /
My Tomos Estoril fit up fine without any modifications. I did have to take the kickstand off to mount it, but was able to put it back on afterwards. Did end up bending it some to line up the bracket better tho.
> I am looking at.
https://www.treatland.tv/exhaust-chamber-p/chamber-black-28mm.htm
I meant like this
