(Newby)Startup trouble polini e50 j.c penny pinto, need ideas?!?
Hank Aguinaldo /
After i pedal start the bike lights come on, but once i go to throttle it just cuts completely off? Any ideas what could be causing this? Heard it could be poor oli/gas mix some say jet could be clogged?
Re: (Newby)Startup trouble polini e50 j.c penny pinto, need ideas?!?
Probably Fred /
More history of previous owner setup, was the engine seized before, what's the what timing, carb, what jetting,
Usually if you don't give no answers you don't get no answers, give no info or poor info you get the same because we can't guess.
Hank Aguinaldo /
Puch e50( with a Polini 65cc cylinder kit ...race crank and treats cdi ignition with performance clutches
what carb and jets
Hank Aguinaldo /
Bing 14 carb, dont know current jets
A 14 Bing/14-intake 222 atomizer 24 slide 70 jet will run but 15 Bing is better...
Probably Fred /
No 70 jet in 14mm bing more like 76-80 jet, 222 atomizer when running a a 14mm bing. Polini reed kits needs a way bigger jet and a rich needle
Princess Rapunzel /
Mine's ok with a 74 jet in a 14/14, I think 70 might be a bit lean at sea level.
Probably Fred /
14.14 Sha is not a bing carb that has a needle
It jets different usually less then a bing and I'm not even sure if dellorto Jets and bing a Jets are the same
Jet size chart
yeah sha sizes are bigger than bing by a lot.
i start tuning 14/15 bing polinis at 96 and work my way down. think i've got 92 in my current setup? fat and happy with a chincy china air filter.
Probably Fred /
E50 polini with estroil pipe and 15mm bing, #2.17 atomizer, I jetted in at #90 jet, #24 slide, 2 ring needle, one clip rich on needle .
E50 polini with MLM pipe and 15mm bing, #2.17 atomizer I jetted in at #92 jet, #24 slide, 2 ring needle, one clip rich on needle ,
Za50 polini with estroil pipe and 15mm bing, #2.17 atomizer, I jetted in at #88 jet, #24 slide, 2 ring needle, one clip rich on needle.
Alternate jetting running a #222 atomizer in a 15mm bing for additional gas cooling with same setups as above jetted in at #84-86 jet but required holes in the slide for the engine to idle.
Princess Rapunzel /
I meant 14 bing/ 14 intake, I'm not talking about SHA's
Pretty sure this is Calvin's old pinto but de-radified.
Make sure you got plenty of gas in the tank and its on and flowing into the carb bowl mang.
I was just copying what is printed in the Polini kit # 144.0150 pamphlet....
1/14/161 Bing carb ...
