puch e50 not perfoming - sputtering
Simon St. James /
heya gang,
Been having problems with the ped recently.
1980 puch maxi
e50
70cc reed
14 bing
78 jet
needle 2nd to lean
stock points
plug ngk b6hs
This thing flies! But recently, on one of my rides home the bike started to sputter on me, pretty severely. Goes from WOT to not budging over 15-20mph. I can't get it over the mid range, it just kinda tops out there. I thought it was the carb so i cleaned it, nada. Went through the fuel and timing. Currently the point and ignition are at :
plug gap - .017"
point gap .017"
timing - 16 degrees
I'm at a loss. Was great until it wasn't. The overall acceleration is great but then it stops accelerating around 15mph and sputters. Idle is fine. I've tried to advance and retard the timing, should i try harder? Any insight would be great.
Thanks
Re: puch e50 not perfoming - sputtering
Try a hotter plug. Maybe you've fouled it pretty badly.
I'm having similar issues, also at a loss
except my idle is shit too
Shit idle is usualy an airleak. Check for air leaks before anything else
Sometimes I fail to tighten the plug/ plug boot, jet or intake/exhaust. And sometimes when I clean carbs the rubber seals don't sit flat in the grooves.I usually ck those first when it's a mysterious problem.
Condenser maybe.
Simon St. James /
Update:
Its running better, but not much.
I located what seemed to be the problem to the ignition coil/mount. Vibration from the ped loosened the mounting bolt of the bosch ignition coil causing a faulty connections and a the negative lead to come off. After putting in a new bolt and reattaching the negative lead from the coil to the mount, the ped ran much better. Seems to running well/normally until I hit top speed.
For some reason my ped likes to stall/bog just near top end. It'll run well throughout the powerband until I'm riding at WOT, this is at about 250 degress. Once I hit WOT for about 45 seconds the bike cuts out until it reaches lower rpms. At that point I can't turn the throttle past 1/4 turn without it bogging. Once this happens I'm stuck in low rpm. I'll be able to throttle it up if the engine cools a bit riding in low rpm, but not for long without it bogging out again.
I'm at a loss.
Have you put in a new spark plug yet? Sounds like it's either fouled or you've got some bad gas in the tank. Sometimes fresh gas and a fresh plug will do amazing wonders.
Check your reeds bro
Check your reeds brother!
Simon St. James /
I put in a new plug, set the gap at .017. Nothing. Put fresh gas too
I'll check the reeds in the am.
Simon St. James /
Still can't figure it out,
Seems like my e50 just wants to cut out at WOT with head temps above 250 degrees farenheit. As soon as I hold WOT there she'll bog out before getting to lower rpm where she can revive herself.
What are some things I should check if this happens when the ped gets hot?
Probably Fred /
Not jetted/tuned correctly
condensor
Down jet 1 and see if it's better
That same thing recently happened to my wife's Maxi and after cleaning the carb, fucking around with jets and searching for air leaks, it ended up being a loose ignition wire.
show me da fresh plug
Condenser? Maybe, let us know did you try it.
