Good kit for a ZA50?
Hey all,
I have a 1980 magnum II ZA50 and am looking to kit. I am also not looking to change my carburetor which is a 15mm bing. Is there any kit that would allow me to keep my current carb and also work well on the ZA50? I hear that the gilardoni is good but I'm not sure if I want to spend that much on my first kit.
Re: Good kit for a ZA50?
You will love almost any 70cc kit you can buy. I'd recommend something easy for your first kit.
This one would do you well.
https://www.treatland.tv/puch-70cc-cylinder-treat-kit-people-p/puch-treat-kit-70cc-head-party.htm
You'll shoot your eye out kid
this is a good one, if you must kit. pair with a 70cc head as well, it will do nicely with 15 bing.
https://www.treatland.tv/puch-airsal-kit-p/puch-airsal-44mm-kit-02030844.htm
Dirty30 Dillon /
The KStar/Treats kit is great, case match and plop it on.
Then, if you wanna go faster, just a little port work really brings them to life.
Also, they are pretty hard to kill.
It looks like the treat/kstar is a good bet. Any gearing recommendations or other tuning things I should do along with it? Like I said this is my first kit.
The 44 actually works better with a stock 2hp head(i think i had a #3 on mine)than one of the kstar 70cc hi comp dudes. All the airsal kits have a decomp hole in the top of the cylinder so you either have to fill it or make sure to run a head with a proper sealing surface. Definitely get a proma circuit or estoril for any kit you eventually decide on.
Dirty30 Dillon /
^^^ agreed on the pipe choices.
And definitely changup the gearing. probably between 19x37 to 20x35 will work really well with that setup.
Probably Fred /
Perfect timing and jetting is a must not to mention having a good crank/crank bushing and nonleaky seals with good bearings. Run a all around power pipe like a circuit, Proma or estroil
Make sure you order and run a head temp gauge so you know if your running hot.
