Re: More variating variatorness dinging
Graham Motzing /
i would check to see if the dinging is coming from the rear pulley being over-travel and binding up.
the contra pulley has just slightly more travel than the front pulley, so if the front pulley goes too far, it will put too much pull in the belt and a thrust on the crankshaft and driveshaft (trans input shaft) which is bad bad bad.
(3 bad)
the 12, 10 mm measurement i'm guessing is based on my blog or a similar account of how to notch variators.
if you cut past that, you'll end up with the problem as described, weights travelling too much. I don't know if its better to have the window big and counteract with washers, or cut the window smaller, i haven't tried the 'harvey' method with washers to compare. sounds like folks are running it and it is satisfactory.
  More variating variatorness dingingTopic by: Julie the Wizard Julie the Wizard 10/05/14 12:50AM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 02:03AM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/05/14 02:13AM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 02:22AM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/05/14 07:00AM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/05/14 07:06AM
  Re: More variating variatorness dingingRe: Ryan . Ryan . 10/05/14 02:14PM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 03:25PM
  Re: More variating variatorness dingingRe: Ryan . Ryan . 10/05/14 03:48PM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 03:57PM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 04:31PM
  Re: More variating variatorness dingingRe: Ryan . Ryan . 10/05/14 04:32PM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/05/14 10:05PM
  Re: More variating variatorness dingingRe: Ryan . Ryan . 10/05/14 10:47PM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/06/14 12:00AM
  Re: More variating variatorness dingingRe: Neil Burgess Neil Burgess 10/06/14 01:47AM
  Re: More variating variatorness dingingRe: Neil Burgess Neil Burgess 10/06/14 01:52AM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/06/14 03:33AM
  Re: More variating variatorness dingingRe: Dirty30 Dillon Dirty30 Dillon 10/06/14 10:33AM
  Re: More variating variatorness dingingRe: Graham Motzing Graham Motzing 10/06/14 10:41AM
  Re: More variating variatorness dingingRe: Neil Burgess Neil Burgess 10/06/14 10:16PM
