Re: More variating variatorness dinging
Ryan . /
The belt should ride just slightly above. Washers would help protect the weights from getting jammed under the sharp edge of the ramp plate. This would gouge them and possibly stick the pulley at full travel, it happens when you notch. To combat it people have run oversized weights, or I suppose limiting washers.
The size of the windows or how far into the pulley wall the ramps run has nothing to do with it. Sounds like it was done right. Its just that getting the weights out that far will get them stuck or cut. You could try rounding the edge of your ramp plate for piece of mind.
As for the sound... Beats me. So many things could make that sound.
  More variating variatorness dingingTopic by: Julie the Wizard Julie the Wizard 10/05/14 12:50AM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 02:03AM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/05/14 02:13AM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 02:22AM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/05/14 07:00AM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/05/14 07:06AM
  Re: More variating variatorness dingingRe: Ryan . Ryan . 10/05/14 02:14PM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 03:25PM
  Re: More variating variatorness dingingRe: Ryan . Ryan . 10/05/14 03:48PM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 03:57PM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/05/14 04:31PM
  Re: More variating variatorness dingingRe: Ryan . Ryan . 10/05/14 04:32PM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/05/14 10:05PM
  Re: More variating variatorness dingingRe: Ryan . Ryan . 10/05/14 10:47PM
  Re: More variating variatorness dingingRe: Steve Clark Steve Clark 10/06/14 12:00AM
  Re: More variating variatorness dingingRe: Neil Burgess Neil Burgess 10/06/14 01:47AM
  Re: More variating variatorness dingingRe: Neil Burgess Neil Burgess 10/06/14 01:52AM
  Re: More variating variatorness dingingRe: Julie the Wizard Julie the Wizard 10/06/14 03:33AM
  Re: More variating variatorness dingingRe: Dirty30 Dillon Dirty30 Dillon 10/06/14 10:33AM
  Re: More variating variatorness dingingRe: Graham Motzing Graham Motzing 10/06/14 10:41AM
  Re: More variating variatorness dingingRe: Neil Burgess Neil Burgess 10/06/14 10:16PM
