Calling all moped gurus
I ride a 1978 jc penney pinto 2. I just purchased a puch techno estoril pipe to get some extra lower end torque and looked past getting the new jets somehow. I need recommendations for parts I need to pick up to match the pipe and not destroy my block. As well as getting new jets, was wondering if a new carb/intake would be a good idea. Also I am having trouble with the pedals and stand hitting the new pipe due to the expansion chamber. Any suggestions?
Re: Calling all moped gurus
Jets, 14 or 15 bing would be great. match the intake if possible and grab one of these for your pedals
https://www.treatland.tv/SearchResults.asp?Search=mlm+pedal
Dirty30 Dillon /
If you have a stock motor, don't worry about the carb and intake so long as you have a free flowing filter of some kind. 14 Bing's are great stock carbs.
Jets are a must, do not ride it without/before jetting.
As for the pedals, either bend the left hand crank out of the way, or buy the MLM pedal shaft extender.
wow next level shit right here, so glad i clicked on the thread.
Yep, this thread needs the best of the best in here right away.
MLM makes great products, but personally I would buy a magnum length pedal crank shaft
https://www.treatland.tv/puch-magnum-pedal-crank-shaft-260mm-p/puch-magnum-pedal-crank-260mm.htm
and the correct sized spacer
https://www.treatland.tv/SearchResults.asp?Search=crank+spacer+pedal
It's a stronger combo. The MLM extenders can strip with a lot of pedal starting.
If you take cotter pins out hammer them gently back in, don't try to pull them in with the nut it will strip.
