stock moby porting...again
i'm rebuilding my 50v...not kitting
stock everything except for a 14mm clone carb and 15mm shorty intake...
i've read and re-read the right way to port a moby stocker...
my question is...
can i choose to port the exhaust only (since my carb falls in the accepatble limit for the intake - 14mm) and then cut the piston skirt in an arc?
i really don't want to lose any low end...thx!
also, i have the stock cashew exhaust...is there a way to de-restrict it?
it has the straight pipe that slides to the front of the exhaust.
Re: stock moby porting...again
scott middleton /
Not your exact exhaust, but same idea...
here
Matt Madden /
thx! yeah I have the new style...the slowest one...: (
kind of a pain to modify...
scott middleton /
Matt Madden /
thx! yeah i saw that...everything is easy except removing the outlet tube and welding a new one in there...lol
might open the baffle plates some...
what i really need to know is if just raising the exhaust a smidge and cutting the piston skirt in an arc for a smoother transition would be help or hurt the low end...
scott middleton /
My understanding is that as you mod to get more top speed, you loose low end and vice-versa. Somebody wiser will chime in I'm sure to set the record straight.
That said, I did exactly what you are proposing, and I liked the results. Felt like I did loose a tiny bit off the line, not bad though. Top speed went to 30ish. Small gains can be had modding the clutch. (edited)
