Made New Jawa Thyristor
adam branson /
Well Ive just made up this thyristor (for jawa 207 )
I solder it all up and just made an placed in a plastic container for now until i find something smaller to put it in
I havent had time to test it out i just broke a piston ring and reordered it should be here thur
so as soon as rings get here ill test out and will let u know how it works!!!!!!!!!!
Re: Made New Jawa Thyristor
Jeremy Homser /
You should put that in a small project box and seal it in resin to keep the components from jiggling .
it might need a heatsink on that lil' SCR/transistor guy there.
nice, ^^like your project box
year of the jawa is happening... just saying.
I like this thread.
Andrew Squiggman /
ADAM RIS Wrote:
> I like this thread.
ˆ this
adam branson /
well got piston rings on and started and rode a little today
so hooked up diy thyristor and it works got good spark off of
not going to run just yet want to find box it fits in better
just say year of jawa
i did that once, thing would fire serious bolts of lightning
then i rigged a positron bicycle shifter (it's a push/pull cable) so i could manually adjust the timing by pushing or pulling a loose stator. it didnt work very well...
Kiel the Canuck /
Hard to tell from the picture... the solder joints might be a bit "cold"
I would also keep an eye on heat levels on that. Still, looks like a nice candidate for a simple PCB layout. These thyristors blow pretty often, huh?
adam branson /
it is my understanding that they are prone to failure
when i got jawa ii 1st ordered before testing
(seller worked and motorcycle shop and he couldnt get to go)
im still using purchased one
but i like to make/build own stuff
so i ordered parts
to make a back up
Kiel the Canuck /
> failure
> get to go)
> so i ordered parts
> to make a back up
Cool!
If you'd like to make it a bit more tidy/compact someday, some copper veroboard or even copperless perfboard
https://www.amazon.com/dp/B008CJJKKM/
) would be a good idea.
The leads go through the holes, then you solder on the other side. Then you can arrange the parts tighter together and they stay mechanically secured.
Radio Shack has those boards and project boxes too, some with metal for heat sinks.
