Honda express kit, pisses oil
put a 70cc kit on my express
rips, runs and rides great, top speed sumwhere in the low 40mph range with a weak-ends pipe
my ONLY complaint is that when I hit the powerband the breather on the back side of the trans PISSES oil all over the back tire
so I put a hose on that breather nipple and ran it really far away from the back wheel
it still shoots oil when u rip it but at least now its not on my tire..
anyone eever have this problem before with a kitted express?
ive had multiple non-kitted Honda express bikes and they never did this
Re: Honda express kit, pisses oil
Too much oil?
nope it was changed before the kit and the level was even w the fill bolt, only thing I can think is that the trans now spins sooo fast that it kicks oil up thru that breather, but that's only a guess
Your tans case is too full. Unless you had a massively blown crank seal there would be no pressure buildup in there. You are just slinging the oil at high speed. I filled mine to the bolt too and it would seep through the breather even when the bike was sitting, its too much. (edited)
okay good too know! thought maby their was a problem or idk
What weight did you use?
Overfill of trans oil/wrong weight is a common performance robber of nopeds.
