Re: a35 tomos need a parts list
Saabsonettguy . /
Use c-clamps or vise grips for the clutch springs, work your way around and use a clamp to hold the spring in the slot while you get the last part over those little metal tabs. Put the rings in the cylinder, slide them down with the piston about an inch, measure the gap with a feeler gauge if the gap is too small you'll need to file the end a little bit. Now carefully instal the rings onto the piston (make sure the ends are right side up, and if you have two different rings make sure to put them in the right place). They will open up just enough to fit, but too much will snap them. When you install the piston align the ring ends with the pins in the ring groove and compress the rings with your thumb and index finger on the side of the piston where the transfers are, then slide the cylinder down with the other hand. Go slow, if it doesn't fit you're doing something wrong so try again.
  a35 tomos need a parts listTopic by: r vance r vance 09/12/14 02:41PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/12/14 08:22PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/13/14 03:10PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/12/14 08:47PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/13/14 06:36PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/17/14 10:08PM
  Re: a35 tomos need a parts listRe: Overpriced Parts Overpriced Parts 09/13/14 07:03PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 02:32PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/14/14 03:41PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:01PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:03PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:18PM
  Re: a35 tomos need a parts listRe: Steve Clark Steve Clark 09/14/14 10:04PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/14/14 10:38PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/15/14 01:36AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/23/14 09:10PM
  Re: a35 tomos need a parts listRe: Weak-Ends Tj Weak-Ends Tj 09/18/14 08:46PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/19/14 09:38PM
  Re: a35 tomos need a parts listRe: Graham Motzing Graham Motzing 09/19/14 11:25AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/19/14 11:39AM
  Re: a35 tomos need a parts listRe: Dirty30 Dillon Dirty30 Dillon 09/19/14 12:04PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/20/14 07:42PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/20/14 10:37PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/21/14 11:05AM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/21/14 01:24PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 06:22AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 06:39AM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/22/14 09:52AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 11:13AM
  Re: a35 tomos need a parts listRe: Weak-Ends Tj Weak-Ends Tj 09/22/14 10:32PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/23/14 09:41PM
