Re: a35 tomos need a parts list
Saabsonettguy . /
There is no such thing, not for a moped, or any other type of engine. I don't know anything about running an engine as fast as possible downhill with no load, but I have to wonder how high the engine will actually rev with a top end limiting pipe, small carb and airsal cylinder. On level ground I don't think that setup would turn more than 10k. A stock tomos cdi would cut out somewhere around there, and points would probably be useless over 11k. The pipe and carb would obviously limit rpm also. A large part of the problem may be lubrication. The faster the engine turns, the more oil it needs. Since you stopped right after the engine died, pull the top end and see how much oil is in the crankcase. I bet it's nearly dry.
r vance Wrote:
> the real question is how can i make the engine
> unbreakable
  a35 tomos need a parts listTopic by: r vance r vance 09/12/14 02:41PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/12/14 08:22PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/13/14 03:10PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/12/14 08:47PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/13/14 06:36PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/17/14 10:08PM
  Re: a35 tomos need a parts listRe: Probably Fred Probably Fred 09/13/14 07:03PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 02:32PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/14/14 03:41PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:01PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:03PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:18PM
  Re: a35 tomos need a parts listRe: Steve Clark Steve Clark 09/14/14 10:04PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/14/14 10:38PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/15/14 01:36AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/23/14 09:10PM
  Re: a35 tomos need a parts listRe: Weak-Ends Tj Weak-Ends Tj 09/18/14 08:46PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/19/14 09:38PM
  Re: a35 tomos need a parts listRe: Graham Motzing Graham Motzing 09/19/14 11:25AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/19/14 11:39AM
  Re: a35 tomos need a parts listRe: Dirty30 Dillon Dirty30 Dillon 09/19/14 12:04PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/20/14 07:42PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/20/14 10:37PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/21/14 11:05AM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/21/14 01:24PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 06:22AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 06:39AM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/22/14 09:52AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 11:13AM
  Re: a35 tomos need a parts listRe: Weak-Ends Tj Weak-Ends Tj 09/22/14 10:32PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/23/14 09:41PM
