Re: a35 tomos need a parts list
Saabsonettguy . /
It sounds like you toasted the big end connecting rod bearing. If you take a look at it, I bet the counterweights are blued from all the heat. If you're lucky that's it, but if the rollers get loose it can take the cylinder and piston out with it. You could use an aftermarket crank like the aluminum stuffed racing crank, or have the existing crank rebuilt with a new rod kit. Make sure to use something with high quality bearings. Same goes for the main bearings, you don't need ceramic bearings, but you should use high quality bearings from a name brand. Why are you running lower gearing than stock? Stock is 26x22. Running something like 28x22 will help lower the rpm. I imagine with the 15 carb and estoril you probably aren't going to rev that high on level ground, but blasting down hill is a good way to wreck something. If you're going to run silly high rpms you'll also need to increase the amount of oil in your premix. (edited)
  a35 tomos need a parts listTopic by: r vance r vance 09/12/14 02:41PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/12/14 08:22PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/13/14 03:10PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/12/14 08:47PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/13/14 06:36PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/17/14 10:08PM
  Re: a35 tomos need a parts listRe: Probably Fred Probably Fred 09/13/14 07:03PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 02:32PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/14/14 03:41PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:01PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:03PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:18PM
  Re: a35 tomos need a parts listRe: Steve Clark Steve Clark 09/14/14 10:04PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/14/14 10:38PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/15/14 01:36AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/23/14 09:10PM
  Re: a35 tomos need a parts listRe: Weak-Ends Tj Weak-Ends Tj 09/18/14 08:46PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/19/14 09:38PM
  Re: a35 tomos need a parts listRe: Graham Motzing Graham Motzing 09/19/14 11:25AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/19/14 11:39AM
  Re: a35 tomos need a parts listRe: Dirty30 Dillon Dirty30 Dillon 09/19/14 12:04PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/20/14 07:42PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/20/14 10:37PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/21/14 11:05AM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/21/14 01:24PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 06:22AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 06:39AM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/22/14 09:52AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 11:13AM
  Re: a35 tomos need a parts listRe: Weak-Ends Tj Weak-Ends Tj 09/22/14 10:32PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/23/14 09:41PM
