a35 tomos need a parts list
r vance /
ok so i got a 93 tomos golden bulett tt lx 2 speed automatic with an a35 engine
so i started slappin parts on
-15 mm sha carb
-15mm sha intake
-79mm jet
-airsal 70cc kit 44mm piston
-25t front sprocket
-tecno estorol exhaust
-crome piston rings
-320mm rfy nitrogen rear shocks
new clutches
new springs
cables
leavers
everything i thought i needed
also waiting on a 26t rear sprocket .
stock f 26t my gearing plan f 25t
r 22t r 26t
for all the torque im trying to build a gas gas bike from it
ok so i put this all on and hit the rd and everything was goin fine till i hit a downhill section and the speedo spun all the way back to 0 without signs of slowing . was stock speedo but im guessing around 65 or more
something in the bottom end gave out where the piston arm meets the crank now pops n cracks moves a bit also
decided to go with the aluminum stuffed racer crank thing from treat.tv
so now my question should i just replace the pin at crank connection .or..crank n all ...
if i replace crank n all should i go with better than stock bearings ?. if so what kind ?. i was lookin at ceramic bearings claim high rpm .
my main question is
any other parts i should go ahead and grab while im at it ??///?////////
  a35 tomos need a parts listTopic by: r vance r vance 09/12/14 02:41PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/12/14 08:22PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/13/14 03:10PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/12/14 08:47PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/13/14 06:36PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/17/14 10:08PM
  Re: a35 tomos need a parts listRe: Probably Fred Probably Fred 09/13/14 07:03PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 02:32PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/14/14 03:41PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:01PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:03PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/14/14 09:18PM
  Re: a35 tomos need a parts listRe: Steve Clark Steve Clark 09/14/14 10:04PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/14/14 10:38PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/15/14 01:36AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/23/14 09:10PM
  Re: a35 tomos need a parts listRe: Weak-Ends Tj Weak-Ends Tj 09/18/14 08:46PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/19/14 09:38PM
  Re: a35 tomos need a parts listRe: Graham Motzing Graham Motzing 09/19/14 11:25AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/19/14 11:39AM
  Re: a35 tomos need a parts listRe: Dirty30 Dillon Dirty30 Dillon 09/19/14 12:04PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/20/14 07:42PM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/20/14 10:37PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/21/14 11:05AM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/21/14 01:24PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 06:22AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 06:39AM
  Re: a35 tomos need a parts listRe: Saabsonettguy . Saabsonettguy . 09/22/14 09:52AM
  Re: a35 tomos need a parts listRe: r vance r vance 09/22/14 11:13AM
  Re: a35 tomos need a parts listRe: Weak-Ends Tj Weak-Ends Tj 09/22/14 10:32PM
  Re: a35 tomos need a parts listRe: r vance r vance 09/23/14 09:41PM
