TP for my bing hole
I bored a bing out to 14 mm to accommodate the 14mm intake on my motto guzzi. It's uber rich at idle. So I'm thinking drill a hole or make a notch somewhere so it can breath at idle.
Where?
It runs fine otherwise. Little rich up top just when I want it. Anyways thoughts, comments and personal experiences anyone?
Oh and the float needle doesn't leak.
Re: TP for my bing hole
Probably Fred /
Square bing or round ?
Probably Fred /
If round slide put holes in the slide high up so when the throttle is opened they are blocked so just used at idle. start at 3/16 and make bigger if needed because the spring blocks the holes some (edited)
It's a round! Thanks so much nailed it! Well see what that does
sookia sookia /
follow up after the you drill the hole!
It's gonna be a while. Changed out the crap tranny fluid with the correct oil and rode it for a good hour. Next day it's super lean and smoking like crazy. think I ate a crank seal. Went up 8 jet sizes and its still lean up top. This is after i did all the obvious and cleaned the carb checked for air leaks etc. Gonna make a new thread on that issue before I mess with the carb.
Bummin. : (
Old seal is out. Just ordered a new one.
blarga flarga /
I did this on mine and it performs fantastically. Now I can be rich up top, and not bog out when slowing down
Drilling out bing slide for leaner idle
Where's my water? /
I'm just gonna add some search keywords to my post because It took me forever to find the thread again after stumbling across it a few days ago... maybe it'll be easier for other people to find the info.
It just so happens that I have to do exactly this to my new 15mm clone carb.
drill drilling hole slide bing carb carburetor lean rich idle lowend low end bog
Also, 3/16 seems way big
Where's my water? /
did you mean 3/32? I'm holding a 3/32 bit in my hands right now, and it looks like that's the same size as the hole in your picture; 3/16 is like a quarter of the entire diameter of the slide...
Probably Fred /
I meant you could go up to as big as 3/16 start at 3/32
Where's my water? /
gotcha. I started at 3/32 and I'm gonna stay there for now, it made a significant difference for me, so super thanks for the pics, btw :)
I ended up tearing down the whole engine replacing all the seals and gaskets. Couldn't afford bearings this week but it wasn't hard to do anyway so next time.
Anyways.... I started over with adjusting everything because it had a bad seal. I spent some time finding the sweet spot with the jetting and slide and bam it idles fine now. Doesn't need the hole. Actually kind let down that I didn't get to try it. Whatever.
