Re: Vespa lighting, ways to make it brighter?
Maciek Dub /
Kinetic 12v light coil paired with a regulator / rectifier. You'll probably have to float the ground, conveniently with that coil the ground end of the wire is bolted down with a connector so it's easy.
There's also a tricky way to wire the three-coil setup for 12v.
Gl
~M (edited)
