molossi springs on a v1????
Mr BadDadsClub /
has anybody ever used these springs on a v1 clutch?? i had a set of blue springs for my v1 and lost one, i compared it to the molossi ones, and there similar. https://www.treatland.tv/malossi-scooter-clutch-springs-set-p/malossi-springs-299605.htm
Re: molossi springs on a v1????
simon thokaar /
bought some last week... not even close. I was able to get 1 green spring on along with a stock spring. Hell.. ill take some pictures of another clutch i was trying to fit them on the other day using anvils and c-clamps to try and stretch them..
Ive used red derbi springs in a morini which has a similar dimension spring.
Mr BadDadsClub /
beke OP
yeah, the greens look a tad tight huh.
simon thokaar /
yeah.. they are the "lightest" of the bunch too.
treats was out of the red derbi springs, i thought about trying the white ones, but figured they might be too strong for my setup. Im tempted to just buy the variety packs of springs from lowes and see if any of them are strong enough. Its something to do while waiting 3 months for the springs from '77 to arrive.
Mr BadDadsClub /
beke OP
im so fucking pissed i lost my other blue spring. fuck.
I keep hearing about the blue springs breaking, although maybe that's only with serious builds? I plan on using scooter springs.
Blue springs are GY6 springs. They will break after 1,000 miles or so. They're made to be used in groupings of three. Crudely using two on a stock clutch will eventually lead to breakage. Buy them on ebay for cheap.
^correct. They also work in a qt50. Haven't had any break yet though.
This
simon thokaar /
I got some real ones from angel yesterday, i hope they last longer than 1k miles... i do that in a month.
> month.
One way to extend the life of the springs is to make sure your shoes are weighted equally and to make sure the clutch body itself isn't warped or starting to 'butterfly' out. Double check everything for quality and balance.
I gave in and purchased a hammer after a couple years of breaking springs. They use GY6 as well. Much more durable and reliable because it uses three springs instead of two.
simon thokaar /
Crazy Wayne™ Rocks, LA french suck Wrote:
> You need to mod the V1 clutch or it will fail with
> those springs.
> V1 stock clutch mods.
> https://www.mopedarmy.com/forums/read.php?7,2982365
> https://www.mopedarmy.com/forums/read.php?7,3007427
> ,3007427
> https://www.mopedarmy.com/forums/read.php?7,2001031
> V1 starter clutch fix
> https://www.mopedarmy.com/forums/read.php?7,2047734
> ,2047900
yeah.. ive read all those and about everything in your profile a few times, very helpful info, thanks.
Mr BadDadsClub /
beke OP
very helpful. yep. thanks
>>>taykoff [s2m] /
Also, to ensure maximum longevity of the Blue GY6 springs, make sure you install them with one spring flipped from the other. If you notice, the hooks on the springs aren't equidistant from coil; therefore, by flipping one spring you can equalize the centrifugal forces to the clutch shoes more better...
