Re: Variates too early...how to fix
Ryan . /
If by too early you mean that you are not reaching the rpm you desire, then yes you need to go lighter. You should check your rear pulley to be sure that the contra spring hasn't broken or collapsed. Most stock variated bikes though have VERY heavy stock weights, and will require quite a lot less to get the higher rpm power. On my bike (not a vespa) had about 32g, and I run ~16. An NU50 I worked on had over 50 grams! and runs 18-20 now..
