throttle cables on shas
Got a stupid sha carb now. Do I really need an adjuster? And how the hell do I get one on if each end has a nob? cut and solder? cuz that's obnoxious. Damn mopeds are awesome! Frustration. . .
Re: throttle cables on shas
you can shove the carb end of the cable through the adjuster. itll fit dude.
scott middleton /
and if it doesn't, grind it down a bit. (edited)
If a cable is that big of a problem, mopeds might not be for you.
use a mini knarp on the throttle side silly...
