Re: Puch Maxi, Hard to Start, Won't Stay Running
Overpriced Parts /
Yeah so with the high flow filter and aftermarket exhaust you're running Lean/bad you need to upjet your carburetor for correct fuel air mixture.
Put the choke on a little bit if it runs a little better with the choke on that means you're running lean
