Urban variator
garrett truebenbach /
I have an 83 urban stock 50cc with pipe and vm20 with a 200 jet and runs great only prob is with the stock belt but it only does like 33 on a flat and I think the only reason is the gearing so I bought a 31 belt but take forever to accelerate . I think I need to put lighter wheights in the vario but I don't know how to do that where to get them or wich ones I need / fit on it
Re: Urban variator
16x13 weights, treatland, get a scale.
Re: Urban variator
Probably too large of a carb as well for a stock cylinder.
Re: Urban variator
Dirty30 Dillon /
Whoa, that's a fat jet you're running. Sounds like you've got a leak somewhere that's killing your power and being overcompensated with jetting.
Re: Urban variator
I don't even know what a urban is, but it's dual variated right?
If so, going down from the stock 33 to a 31 belt would just fuck up the variators range and could snap the crank. Thats if the numbers you are posting are refering to belt length.
Re: Urban variator
The bx31 is not actually 31 inches long.
Re: Urban variator
Jet sounds fat too. I noticed that was odd as well?
Re: Urban variator
Forget my last post, I somehow read this as your stock belt was a 33 and now you are running a 31...
Re: Urban variator
So I opened the variator and there is like grease all inside covering the weighs Is that suppose to be like that I will post a pic in the morning but if I put new weights should I leave the grease/oil in or clean it out
Re: Urban variator
Yes the pulley is greased and the dust cover has a gasket. The grease is for low maintenance and long life of the weights.
Re: Urban variator
Take half of the stock weights out, It takes a few minutes and is a big improvement. Might not get you to where you want to be but it's a quick free mod.
Re: Urban variator
I did take half out it runs a lot better
Re: Urban variator
Put a yellow 1,500rpm contra spring in the back.
Your cylinder is stock so start with 5gram rollers.
and do some porting.
Re: Urban variator
The yellow spring will that just make the clutch grab later ?
Re: Urban variator
No it will resist the weights and make them act lighter. You are thinking of clutch springs.
Re: Urban variator
Kevin Bishop /
take a 1/8' or 3/16" drill bit and drill out the center of your weights then maybe ramp and put windows in your vaiator
Re: Urban variator
The pulley is a 6 roller, don't just throw hobbit tactics out and transplant them. There is really no need to notch or window anything. The bike will outgear the power it makes long before that.
Re: Urban variator
Kevin Bishop /
Then get rid of the grease and go with graphite instead.
