Re: E50 stock clutch lightening
Derek Stahl /
Bobby Selby Wrote:
> There is no one exact way of doing it other than
> shaving a little weight (equally)off of each
> shoe....some take weight off just the outer edge
> (opposite) end of the pivot end...and others
> lighten the whole shoe but be careful because a
> couple grams too much and you will totally ruin a
> set of shoes and your clutch will never fully grab
> even with the lightest springs...
You need to cut a lot of for this to happen.
85g with heavier then stock springs is pretty good for a mild set-up, 75g with stock springs is also a very good option. I've gone as low as 50g which is about half or less of the stock weight.
