E50 stock clutch lightening
Giovanni Giarratana /
I've been searching and reading about lightening stock shoes but haven't seen anything on how to do it, eg grind drilling sanding etc
Maybe I'm missing a tutorial on it I'm sure this had been covered
Thanks
Re: E50 stock clutch lightening
It's out there, I've done a few write ups on it.
There is no one exact way of doing it other than shaving a little weight (equally)off of each shoe....some take weight off just the outer edge (opposite) end of the pivot end...and others lighten the whole shoe but be careful because a couple grams too much and you will totally ruin a set of shoes and your clutch will never fully grab even with the lightest springs...
You need to cut a lot of for this to happen.
85g with heavier then stock springs is pretty good for a mild set-up, 75g with stock springs is also a very good option. I've gone as low as 50g which is about half or less of the stock weight.
Downhill Harvey (OFMC) /
^^^agreed,
I shaved mine to 88grams
Thank you all, and if I'm not mistaken your taking material off of the actual steel part of the show not the pad
yes, that is correct.
What's the gain?
K Olena Wrote:
> What's the gain?
Later clutch engagement point.
Probably Fred /
> not the pad
What is your set up ?
Stock, modded stock, kit?
Kit with a stock clutch, 70cc kstar kit, stuffed crank, case matched, proma circuit pipe, and an HL-141 tillotson carburetor, stock clutch with blue springs in it
Matt Mahloch -- MBM Customs /
Perfect thank you all!!!
