Gearing for a heavier rider
Hey all I am trying to figure out some options on gearing my puch it has the following:
65 airsal
tecno circuit
3 shoe clutch with blue springs 2 turns in
new stuffy crank and bearings and seals
Vm 18-----yaddda yaddda
I have everything tuned pretty good on the carb and clutch my take off and hill climbing sucks..I weigh 220 so I assume if I lost a few LBS things would be different but it aint gonna happen any time soon.. Was wondering if I messed with my gearing i that would help me get off the line quicker and my hill climbing not sooo slow..
Re: Gearing for a heavier rider
Mikey Antonakakis /
Yes, do it. Of course it will sacrifice your top speed, but such is life.
Are there any ratio suggestions that I should start off with? I think stock is 16x45 I was thinking maybe 14x45....
That's the right move...
muchas gracias
Overpriced Parts /
No don't change gears 16x45 is bad enough to begin with
Just use Kickstart springs in a stock 2 shoe or stock 3 shoe, 3 turns in from flush,Aftermarket 3 shoe is not good .
You will be able to up gear to 18x45 or 16x40 (same gearing) if you have a good clutch
