Re: reed valves make tuning easy?
E Tangert /
my fault ill set the bowl down..
Athena has reeds. plus got a 3 shoe adjustable so it does get a chance to spin up.
v1 is stock clutch which tears ass from a stop when its cold. 5 min into the ride and it deff starts grabbing early, I guess it is heat fade on the springs. unless its the bushing dragging on the crank but I hope not.
tried atf, synthetic gear oils, nd 30weight and the fluids don't make much difference clutch acts the same. if I had funds for the hammer right now..
I guess ill try the 85main I just wonder why the reed need such smaller jet unless they just that much more efficient.
