Sachs tuning
Trying to tune a 15mm Puch Bing carb (not a clone) on a stock 50cc Sachs 505 D motor with Sachs MLM sidebleed pipe from Treats. I'm starting to think I went too big with the Carb/intake and was hoping someone else went down this road before me. I fabricated an intake riser to match the 15mm manifold in order to raise the carb up to fit on the bike (a very nice and clean 1980 Prima that ran beautifully with stock set up). I got curious after riding stock for a while and wound up jumping down the rabbit hole.
I've tried every jet from 58 to 82 with the needle set on the bottom notch and second to bottom notch and four stroke with every combo. The closest I've gotten on the needles bottom notch is with a 68 jet (low/mid range perfect with nice idle). The closest I've gotten on the second to bottom notch is with 74 jet (low/mid range perfect with nice idle). Still four strokes a bit at 30mph on both settings though. Before I move on to the third notch from the bottom I was hoping someone could tell me if I've got an unusable combination of parts to begin with.
At one point a friend reminded me to check for air leaks in the carb and I noticed that I'd damaged the very top gasket so I carefully cut out the profile of the original gasket from a cereal box and am currently using that to seal the top of the carb. Doing that certainly helped a bit but did not fix the problem. The bike does not four stroke with the air filter off. I've tried both metal and foam bing high flow filters.
I impulsively bought the performance parts and everything actually worked pretty well for a while but it was because the intake riser was leaking air. Probably should have left all of the components stock which I could go back to easily but as long as I've got the performance parts I'd like to use them. My goal was to have this bike hitting 35-37 with the stock cylinder while keeping a large sprocket on the back wheel for super strong low/mid range.
Re: Sachs tuning
I actually just got my 15mm bing, I'll be starting down the same rabbit hole this week.
It would seem that you need to down jet if you are still four stroking. You are getting too much fuel for the amount of air it is able to suck in.
Re: Sachs tuning
Are you putting it on a stock Sachs D motor? I'm either missing a very specific variable or have the wrong carb for this motor.
Re: Sachs tuning
I'm putting it on a 504 C. If you are on FB, check out the group: Lovers of Sachs Mopeds. There is a thread there right now with some other folks and their set up.
Also, there are a few i think on the garage on 77.
Re: Sachs tuning
Also I should re-word something I said in the original post. What I said is this;
"I've tried every jet from 58 to 82 with the needle set on the bottom notch and second to bottom notch and four stroke with every combo."
What I should have said is that I've tried every jet from 58 to 82 with the needle set on the bottom notch and second to bottom notch and either four stroke or bog down with too much air no matter what I've tried so far.
Re: Sachs tuning
I have a 15mm bing and clamp on jammy on my sachs and it does 35. And it's an A cylinder. I was also having trouble with it 4-stroking at WOT with every jet I tried without being too lean. I got one of those flat velocity stack looking filters with a screen and it solved my problem. I think I'm running a 76 jet.
Re: Sachs tuning
maybe try different gearing
Re: Sachs tuning
Gearing has nothing to do with jetting. Sachs and Bings go together like weed and hippies. Bings are best when combined with an air filter of some sort...they don't do so well when you just cram air down their throats. I'm not sure on that setup (D, 15 Bing, MLM) but I would expect you to be up the 70s-80s range. Make sure your timing is on point before you mess with jetting. For the Bings, generally the 2nd notch from the bottle (needle) works fairly best. To jet it run it WOT til it four strokes then drop jet sizes til it smooths out. The needle adjusts the low into mid range.
Re: Sachs tuning
forgot you're the wiz
(edited)
Re: Sachs tuning
I'm at 62 with a 12mm round bing on a D with a clamp on expansion chamber, I'm not running an air filter, hope this helps!
PS, its doing 35-37
Re: Sachs tuning
The bike has a 45 rear cog in case I need to pop a wheelie.
Re: Sachs tuning
be careful poppin willies!
